Two KLee Machines
Page 1 of 1 [2 Posts]
iPassenger
G2 patch files: 78
PostPosted: Thu Aug 30, 2007 12:46 am    Post subject: Two KLee Machines Reply with quote  Mark this post and the followings unread
So I read the pdf file and now I know what klee is supposed to be, so here are a couple more structured experiments on the idea.
KLEE Beats.pch2
 Filename:  KLEE Beats.pch2
 Filesize:  3.17 KB
 Downloaded:  1229 Time(s)
Master KLEE.pch2
 Filename:  Master KLEE.pch2
 Filesize:  2.7 KB
 Downloaded:  1226 Time(s)
iP (Ross)
iPassenger
G2 patch files: 78
PostPosted: Thu Aug 30, 2007 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
One problem with the beat one is you can't trigger two beats next to each other, I appreciate this is because of the two consecetive positive outputs, therefore no change in voltage at the gate inputs and therefore no gate. Not sure how to get round this without making it a lot more complex or running the patch at double speed.
KLEE Beats2.pch2
I worked out above problem. Just use gates!
 Filename:  KLEE Beats2.pch2
 Filesize:  3.22 KB
 Downloaded:  1337 Time(s)
iP (Ross)
