Could G2 emulate a Lambda ?
Page 1 of 1 [6 Posts]
a-grume
PostPosted: Fri Nov 23, 2007 9:57 am    Post subject: Could G2 emulate a Lambda ? Reply with quote  Mark this post and the followings unread
Hi all,
I love my Korg Lambda but it's not midi, do you think the G2 could emulate the Lambda string "chorus" ?
Perhaps you already have a patch like this ? Wink
Thanks a lot for help !
a-grume
PostPosted: Mon Nov 26, 2007 11:54 am    Post subject: Reply with quote  Mark this post and the followings unread
HELP Laughing
Embarassed
PostPosted: Mon Nov 26, 2007 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know ... sorry, there are some chorus patches though in the archive .
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Nov 26, 2007 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi a-grume
I tracked down the schematics and some samples on the web.
It was an interesting design, no BBD chorus like it's contemporaries. Instead it uses a three phase lfo to modulate three oscillators that each go to a top octave divider.
This is different to a typical 3 phase chorus which mixes the original signal with the three modulated ones. I think that the string tabs only use two of the three available phases.
The only vcf is reserved for the brass stop, all the other stops use a simple fixed BP and LP filter.
I tried to come up with a patch but it did not sound very close to the samples so I didn't post it.
To be honest, I didn't much like the sound of the samples so was not too enthusiastic. Perhaps you have some better samples that illustrate what you like about the sound?
Regards
Ian
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Nov 26, 2007 2:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed I missed page six of the schematics, it does have a chorus (in addition to the three phase master osc modulation).
Back to patching.
Still interested in a good quality sample, single notes preferred Smile
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Mon Nov 26, 2007 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here we go
Although the organ style dividers produce only square waves, different footages are summed to produce an stepped approximation of a sawtooth so I use sawtooth as the starting point in the poly area.
A three phase modulation is in the FX area and applied to the VA via internal midi so the slot values should be changed if you load into a slot other than A. Note that the FM level knob is being modulated which sort of gives a non Octave/V FM.
The output section is just a couple of filters and the final chorus.
This is just the string part of the ensemble section but might be useful for a starting point. It sounds quite nice and uses little DSP and Memory.
Edit: forgot to connect third LFO to sync and master rate and adjust phase, uploaded fix.
lambda2.pch2
korg lambda strings
 Filename:  lambda2.pch2
 Filesize:  2.07 KB
 Downloaded:  1952 Time(s)
