  Muied Lumens Frequencies
 Forum index » Instruments and Equipment » Chameleon
Changing default interrupt levels on the Chameleon
Page 1 of 1 [5 Posts]
BobTheDog
Audio files: 32
PostPosted: Fri Jul 04, 2008 2:13 am    Post subject: Changing default interrupt levels on the Chameleon
Subject description: Is it safe?
Hi Again,
Is it safe on the Chameleon to change the default interrupt levels for things like ESSIO and HI08?
Andy
lordavon
PostPosted: Fri Jul 04, 2008 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess you'd need to be carefull about how much procxessing you wanted to do.
If you push them too high, you might find you're getting requests for data for the DAC before you've finished processing.
I'd suggest taking a look at the 56303 datasheet to see if it mentions anything about IRQs.
Paul
BobTheDog
Audio files: 32
PostPosted: Fri Jul 04, 2008 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the reply.
I am pretty sure that the ESSIO is already top level, I want to lower it one level and put the HI08 (currently 2nd lowest) on top so I can disable all interrupts apart from the host port.
There seems to be only 4 levels on the 56K.
DrJustice
PostPosted: Fri Jul 04, 2008 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just adding that there's no dangers in the form of anything going on behind the scenes, waiting to be broken - you have the DSP totally to yourself.
DJ
BobTheDog
Audio files: 32
PostPosted: Sat Jul 05, 2008 3:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
