simplest scratch example?
Page 1 of 1 [5 Posts]
MiCR0C0SM
PostPosted: Sat Dec 20, 2008 1:55 pm    Post subject: simplest scratch example? Reply with quote  Mark this post and the followings unread
can someone put together a really simple example of the scratch module? intuitively, i would think it would affect the pitch of audio coming in. but i cant get much of anything except FM type sounds and distortion.
Mick Emouze
PostPosted: Sat Dec 20, 2008 3:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
try this one
scratch_it_01.pch2
basic scratch patch
 Filename:  scratch_it_01.pch2
 Filesize:  884 Bytes
 Downloaded:  879 Time(s)
Mick Emouze
PostPosted: Sat Dec 20, 2008 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
I made another patch and I noticed if the Scratch module is scratched across the 0 or x1 mark it will sound better than scratching on the positive or negative sides only.
Scratch It 3 details:
- Delay module to compensate for mono
- Delay is allowed to ring out when Off is selected
- On/Off control is sent to an inverter to match status
- laid out for easy visualization
scratch_it_03.pch2
Scratch It 03 patch with delay and bypass
 Filename:  scratch_it_03.pch2
 Filesize:  1.29 KB
 Downloaded:  916 Time(s)
MiCR0C0SM
PostPosted: Sat Dec 20, 2008 6:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, but I dont have an audio in on hand. Is the effect possible using internal oscillators?
Mick Emouze
PostPosted: Sat Dec 20, 2008 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, and it sounds cool. Try it with the Scratch It 03 patch, the delay sounds nice.
