Morgan
Posted: Sat Feb 28, 2009 11:17 am Post subject:
have a noodle change variations |
I'd like to have a patch automatically switch variations. I use the midi modules for this, right?
I've previously not used midi in any significant way. Perhaps one of the masters can suggest a course of study?
thanks all. |
Audio files: 278
Posted: Sat Feb 28, 2009 11:51 am Post subject:
Yup use a midi CC send and set it to CC70 and to one of the internal midi channels (slota ... slotd). when done within the same patch it might get a bit confusing at first _________________ Jan
buzzr
Posted: Sat Feb 28, 2009 1:41 pm Post subject:
Does this modify the whole patch? Like randomization? Is there any way to confide the changes to specific modules? When adjusting a knob on a midi controller does it slightly change the whole patch randomly? |
buzzr
Posted: Sat Feb 28, 2009 2:18 pm Post subject:
Ok. I only want to do one thing. I read about the midi variations
I just want to have a morph knob be controlled by a midi controller and that morph knob send random midi cc values. |
Audio files: 278
Posted: Sat Feb 28, 2009 3:47 pm Post subject:
Ah ok ... well in that case give the morph a CC number (right click on its knob), and send random signals to that CC... _________________ Jan
buzzr
Posted: Sat Feb 28, 2009 5:56 pm Post subject:
can you use a morph knob to send random cc's to any part of the patch? i know you can send random cc's from a midi controller. i'm interested in sending random cc's from the morph itself. |
Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
G2 patch files: 626
Posted: Sat Feb 28, 2009 6:59 pm Post subject:
buzzr wrote: | can you use a morph knob to send random cc's to any part of the patch? i know you can send random cc's from a midi controller. i'm interested in sending random cc's from the morph itself. |
The position of a morph knob can be controlled with a CC, random or not. The morph can then affect any knob or group of knobs in the patch by an arbitrary amount. You can use up to 8 morph groups at one time in a patch, each with it's own CC. |
buzzr
Posted: Sat Feb 28, 2009 8:06 pm Post subject:
The question is can you run randomized CC's from a Morph knob? |
Audio files: 278
Posted: Sat Feb 28, 2009 8:08 pm Post subject:
I'm not understanding properly I'm afraid ... what exactly should it do? _________________ Jan
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Sat Feb 28, 2009 9:21 pm Post subject:
You can easily send randomized CCs from a knob (using midi send), but you don't need a morph to do that. _________________ www.gregwaltzer.com |
buzzr
Posted: Sat Feb 28, 2009 10:48 pm Post subject:
Ok. Say I have a morph knob. One of 8. Say I want to use it to adjust 2 oscillator pitches. But instead of it sending 0-127 in a straight line it sends it randomly. In other words, the morph knob sends random cc values instead of linear values. So the pitch jumps randomly instead of normally. |
buzzr
Posted: Sun Mar 01, 2009 9:04 am Post subject:
Something like that yes. Kind of odd that there is no function that I can find so far to assign random to a morph. Kind of overlooking the obvious I think clavia |
buzzr
Posted: Sun Mar 01, 2009 9:05 am Post subject:
I do see in many patches, especially noodles where a random is assigned to a morph knob. How is this done? |
Posted: Sun Mar 01, 2009 9:13 am Post subject:
buzzr wrote: | I do see in many patches, especially noodles where a random is assigned to a morph knob. How is this done? |
I have to say that I haven't seen this myself. Can you point out an example?
buzzr
Posted: Sun Mar 01, 2009 10:40 am Post subject:
Many of Blue Hells patches have it. You look at a morph knob and it's randomly changing. |
Audio files: 278
Posted: Sun Mar 01, 2009 10:51 am Post subject:
Erm well, I do this :
Blue Hell wrote: | Ah ok ... well in that case give the morph a CC number (right click on its knob), and send random signals to that CC... |
buzzr
Posted: Sun Mar 01, 2009 11:03 am Post subject:
Ok. So, how is this done? Say I assign Morph one to controller 15. Now what do I do? Sorry this is a beginners question. I'm using a homemade hardwired midi controller and I can easily program random CC values using the software Midipipe, but I would rather the G2 do all this stuff without a computer. Ughh.. |
Audio files: 278
Posted: Sun Mar 01, 2009 11:15 am Post subject:
Use a MIDI CC send module, connect an unipolar random signal to it's value input, set the CC value in the CC send module to the one you associated with the morph knob and set the Chan(nel) to SlotA (or when the patch is in another slot use that slot instead).
But be sure to click on the MIDI CC module and then press F1, otherwise it might not work _________________ Jan
buzzr
