 Forum index » DIY Hardware and Software » Supercollider
OSC - FAILURE /insertCommandNameHere Command not found
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [10 Posts]
Ataxian
PostPosted: Tue Mar 03, 2009 8:27 am    Post subject: OSC - FAILURE /insertCommandNameHere Command not found Reply with quote  Mark this post and the followings unread
Hi guys, good to see a decent dedicated SuperCollider board on the net!
I have a question about OSC as it has been a while since I last used SuperCollider.
The following code:
Code:
   d = OSCresponder
      addr: s.addr,                        // Default Server addrress
      cmdName: '/a',                     // OSC Message/Command Name
      action:
         arg time, responder, msg, addr, rate;
         //[time, responder, msg, addr].postln;   // Display OSC message in Post Window
         msg[1].postln;
         rate = msg[1];               // msg[1] = /*.* where *.* is the OSC message
         s.sendMsg("/n_set", 1000, \buffer1Rate, rate);   // Send an OSC message to the server
   ).add;
will not let me pass messages to it from Max/MSP 5 as it will tell me that the OSC command (/command) has not been found.
Can anyone explain why this is happening please?
Audio files: 213
G2 patch files: 319
PostPosted: Tue Mar 03, 2009 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome Ataxian,
next time when you have a double post you can simply delete it yourself, that is as long as there was no reply to it.
Sorry to not be able to help with your question.
Ataxian
PostPosted: Tue Mar 03, 2009 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for the warm welcome Blue.
Ataxian
PostPosted: Tue Mar 03, 2009 2:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Problem solved but it only raises another issue, which I would be grateful for someone more knowledgeable than me to explain.
If I change the listening address with the following line:
n = NetAddr.new("127.0.0.1", 7771); // create the NetAddr
then querying the listening address with:
NetAddr.langPort; // retrieve the current port SC is listening to
will still return Port 57120?!
Why is this?
EDIT: Forget that too!
Turns out the NetAddr must only be changed after the server has been booted.
Is there a way to only do commands automatically after the server has been booted?
dewdrop_world
PostPosted: Tue Mar 03, 2009 8:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
The SC client (which handles OSCresponder, OSCresponderNode etc.) always receives OSC on port 57120. That's hardcoded. If you have two instances of sclang running, one will use 57120 and I think the next will roll up to 57121.
Your Max patch must send OSC to port 57120. That's not changeable (sorry).
The server's default port is 57110. You can change the port before booting the server using s.addr.port = (port number). The port number here gets included in the scsynth command, and that is the port the server tries to open.
scsynth -u 57110 -b 1026 -R 0
As far as I know, there isn't a way to change the server's listening port without stopping and restarting the server.
Dunno if this has confused more than clarified. Feel free to ask other questions.
Oh, executing something automatically after boot:
s.waitForBoot({
... stuff in here ...
James
Ataxian
PostPosted: Wed Mar 04, 2009 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much James.
There is one other question I have about OSC, and one general question if I may.
Why can I update the "buffer1Rate" parameter with OSC messages:
Code:
      // define a sample player that will loop over a soundfile
      SynthDef("Buffer1",
         arg outBus = 0, bufnum = 0, buffer1Rate = 1, rateScale = 1;
         Out.ar
            outBus,
            PlayBuf.ar
               numChannels: 1,
               bufnum: bufnum,
               //rate: BufRateScale.kr(bufnum) * rateScale + LFNoise1.kr(2.reciprocal, 0.05),
               rate: buffer1Rate,
               //trigger: ,
               //startPos: ,
               loop: 1            // play the soundfile over and over without stopping
               //doneAction:
      }).load(s);
Yet I can't change the "delayTime" parameter here with OSC messages?!
Code:
      SynthDef("echo1",                         // Synth Definition and NAME
         // Local variables on first line
         var inBus = 0, outBus = 0, signal, echo, delayTime = 3;
         signal = In.ar(inBus, 2);    // Input Signal (inBus)         echo =    CombC.ar   // Define FX (echo)                  (
                  in: signal,
                  maxdelaytime: 10,
                  delaytime: delayTime
         Out.ar(outBus, echo);    // Output Signal         }).load(s);
The OSCresponderNodes are as follows:
Code:
   OSCresponderNode
      addr: nil,   // n                     // Default Server addrress
      cmdName: "/OSC_buffer1Rate",            // OSC Message/Command Name
      action:
         arg time, responder, msg, addr;
         buffer1Rate = msg[1];               // msg[1] = /*.* where *.* is OSC message
         // Send OSC message to the server
         s.sendMsg("/n_set", 1000, "buffer1Rate", buffer1Rate);
   ).add;
   OSCresponderNode
      cmdName: "/OSC_echo1DelayTime",            // OSC Message/Command Name
      action:
         echo1DelayTime = msg[1];
         s.sendMsg("/n_set", 1001, "delayTime", echo1DelayTime);
   ).add;
The second question:
Can you recommend any software (for Mac) that automatically helps with the formatting of SuperCollider code, much like Visual Studio for C++ etc.
dewdrop_world
PostPosted: Wed Mar 04, 2009 8:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
There's nothing inherent in the language to prevent setting the control in the synth, so I have to suppose it's one of a couple of things.
Have you checked to make sure the incoming OSC message is properly received? You can check a couple of ways: by adding "msg.postln;" in your OSCresponderNode, or doing this to see all incoming OSC. (It's a good idea to filter out /status.reply messages from the server, since there will be a lot of them.)
Code:
thisProcess.recvOSCfunc = { |time, addr, msg|
   if(msg[0] != '/status.reply') { msg.postln };
// to turn off dumping:
thisProcess.recvOSCfunc = nil;
Maybe the message never reaches SC, or maybe the OSCresponderNode doesn't get triggered.
Also try tracing node 1001 to see what the actual control inputs are.
Code:
s.sendMsg(\n_trace, 1001);
Somebody did a TextMate bundle (Google can probably help you). I haven't used it but I hear it's more powerful than the built-in SC editor.
James
Ataxian
PostPosted: Thu Mar 05, 2009 8:45 am    Post subject: Reply with quote  Mark this post and the followings unread
For some reason the following line does not prevent status replies (oh well, it's not too important)
Code:
I got it working by setting the fx to a group called ~fxgroup and using ~fxgroup.nodeID as the node.
There's one final problem that is definitely ignorable but still bothers me.
Setting the addr: to anything other than nil will not allow for messages to be received.
So I can't go ahead and set the addr: to NetAddr.localAddr; or addr: s.addr for example. (Where s is the local server)... how strange.
As for the changing of the delay time in the Comb filter:
Changing the values result in weird artifacts and other horrible sounds, is there a way to alleviate this problem (such a interpolating between input values)?
Thanks.
dewdrop_world
PostPosted: Thu Mar 05, 2009 8:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The reason why NetAddr.localAddr does not work in an OSC responder is that this is the address and port that supercollider is listening to. The OSC responder (if the port is given) needs to have the port FROM which the messages are coming. If Max is sending FROM port 7771, then the address given to the OSC responders should be NetAddr("localhost", 7771).
Then Max needs to send TO port 57120. But understand -- the fact that Max is sending TO this port does not mean that the OSC responder should have this port in its address.
I know this is confusing... I'm not sure how else I can explain it to make it clear.
Think of it this way -- the address in the OSC responder is a filter to prevent that responder from taking action based on the wrong source. Supercollider's listening port (57120) is useless as a filter because every message coming into the supercollider language is received at this port! It is meaningful only if it refers to the port that the other application is using to send messages FROM.
CombC -- right now you're sending instantaneous changes in the delay time, which will give you nasty clicks. Try wrapping the delay time in a Lag, to smooth the transition.
// before CombC
delayTime = Lag.kr(delayTime, 0.1);
James
Ataxian
PostPosted: Fri Mar 06, 2009 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent, thank you.
I will leave the addr: as nil for now, seeing as I can't figure out what specific addr: will work for my settings and from what you said.
I've just been looking at your SuperCollider pattern tutorials; v. nice!
