Editor: Param Overview Problem
Page 1 of 1 [2 Posts]
PostPosted: Tue Oct 19, 2004 8:30 pm    Post subject: Editor: Param Overview Problem Reply with quote  Mark this post and the followings unread
in v1.24:
I assign an AUDIO Meter (such as from the audioIn module) to an LED/Knob, but the parameter overview page reports it assigned to the wrong location. The other "Parameter Pages" and the synth seem to work fine.
See Page E3 for example. If a someone else confirms this, I'll pass it on to Clavia.
didje_simpl1.pch2
example of audio->led problem in v1.24
 Filename:  didje_simpl1.pch2
 Filesize:  1.89 KB
 Downloaded:  750 Time(s)
Rob
G2 patch files: 109
PostPosted: Wed Oct 20, 2004 2:51 pm    Post subject: Re: Editor: Param Overview Problem Reply with quote  Mark this post and the followings unread
jksuperstar wrote:
in v1.24:
This is indeed a bug. Sometimes I wonder if assigning the VU displays to rotary encoders wasn't some sort of experiment in the early stages of G2 development and for some VU meters they forgot to remove the option. As not all VU meters can be assigned and they show up false in the Overview. Even worse; when removing them from the Overview with the right-click deassign option sometimes removes other knob assignments. Quite strange...
Niio1
