 Forum index » Instruments and Equipment » DSI Synths
Evolver Editor 0.6
Page 1 of 1 [5 Posts]
alcovy
PostPosted: Wed Jan 28, 2009 5:19 pm    Post subject: Evolver Editor 0.6 Reply with quote  Mark this post and the followings unread
Hello everybody!
Here it is a new version of the freeware DSI Evolver Editor.
I have fixed some important bugs and added a control sequencer.
With this control sequencer you can create dynamic sounds and loops that without it it will be very hard to do.
Remember that it is not finished, but if you have any suggestions, ideas, or find any bugs, tell it to me.
I hope it will be useful!
You can also visit: http://sites.google.com/site/evoeditjr/
DSI Evolver Editor Junior 0.6 - Alcovy.zip
 Filename:  DSI Evolver Editor Junior 0.6 - Alcovy.zip
 Filesize:  843.47 KB
 Downloaded:  526 Time(s)
Audio files: 213
G2 patch files: 319
PostPosted: Wed Jan 28, 2009 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
For an earlier version and some discussion look there , I edited the first post there to point to here.
JLS
Audio files: 27
G2 patch files: 278
PostPosted: Wed Feb 04, 2009 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks - new control sequencer is great Smile
MissyM
PostPosted: Thu Mar 05, 2009 11:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Alcovy i have a problem with your fantastic editor: i can`t install it it says fatal error during instalation.. error installing .NET framework (that i already have anyway) and it points to a log on VSD12B.tmp\install.log that does not exist. if I use the exe directly it loads ok but it seem to do nothing... BTW when i load it I cant go down on the window so I cant access the bottom controlers on the window... Please help!!! thanks
marcellotron
PostPosted: Wed Mar 25, 2009 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Alcovy,
Your editor is a really nice piece of work.
It seems to work Ok, sending sysex messages is normally changing internal parameters of the Evolver.
Sadly, like MissyM, I can't access (and even view) the Play/Stop /Send Actual Program / Reset Program buttons...
The size of the editor's window is much to large to fit my screen (1440 * 900 pixels).
Is there anything to do to solve this problem ?
I'm really looking forward to your answer. Using your editor would really be great.
Anyway, thank you for the time you've spent on creating this editor. The evolver's community is grateful to you.
