 Forum index » Clavia Nord Modular » G2 Patches - Completed » Sequencer - interactive
sequant
Page 1 of 1 [2 Posts]
egw
G2 patch files: 8
PostPosted: Fri Oct 22, 2004 3:13 pm    Post subject: sequant Reply with quote  Mark this post and the followings unread
Sequant is a random sequencer. It does not play repeating patterns. It plays a stream of notes at a given tempo, in the key of your choice. Similar to a random arpeggiator, except the choice of notes is programmed, not entered on the keyboard. The knob assignments are as follows:
Row A: real time controls - filters and levels for sequence and drum.
There is also a global transpose that lets you toggle an interval.
The button toggles and the knob sets the interval.
Row B: sequence setup - key, complexity, octave, range
The key is one of 8 minor keys - D,E,G,B,C,C#,D#
It's easy to customize other keys.
Complexity is the number of different notes in that key that can be played.
Row C: sound - oscillators and envelopes
Row E: delay controls (the default is 1/8D)
Volume is down when the patch is loaded. Variations are not programmed.
sequant.pch2
 Filename:  sequant.pch2
 Filesize:  4.47 KB
 Downloaded:  1136 Time(s)
Audio files: 107
PostPosted: Fri Oct 22, 2004 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very very nice, Greg. This is fun to play with.
banana xxsun
Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master Hail the Master
I like the way you summarize what the knobs do. It makes it much easier to get the feel of playing this patch.
