trig a sequence from the key board
Page 1 of 1 [5 Posts]
heid'
PostPosted: Sun Aug 09, 2009 6:11 am    Post subject: trig a sequence from the key board Reply with quote  Mark this post and the followings unread
Hello,
I am looking for a way to trig a sequence from the keyboard; each time I press a note, the sequencer starts, and when I stop to press the note, the séquencer stops its loop (we hear nothing).
It's a basic question but I don't know how to do it ...
I have tried with the logic module "gate" and the keyboard module but it doesn't work ...
We can work for example on the antimon's patch (everything is here, just the trig mode to add) :
http://electro-music.com/forum/download.php?id=9627
Thank you Wink
heid'
PostPosted: Sun Aug 09, 2009 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, it's perhaps an easy problem, but I don't find the solution... You don't have any idea ?
I'm sorry
Rolling Eyes Wink
heid'
PostPosted: Sun Aug 09, 2009 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, I found the solution; I use the AM input of the ADSR module with a second sequencer to control the volume of the steps; I didn't knew how to use this input Wink
sequence patch.pch2
 Filename:  sequence patch.pch2
 Filesize:  1.65 KB
 Downloaded:  873 Time(s)
Audio files: 369
PostPosted: Mon Aug 10, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's how I'd do it (made in the editor without the hardware or demo, so there may be some bug).
Don't read the posts as often as normal during vacation time. Smile
/Stefan
seq trig.pch2
 Filename:  seq trig.pch2
 Filesize:  1.39 KB
 Downloaded:  1232 Time(s)
heid'
PostPosted: Mon Aug 10, 2009 8:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you antimon; your solution is better, because you use just one sequencer (I have to take a second one, and it's better to get the result with the minimum of modules).
Gate inside Am input : that's what I was looking for. Excellent Wink
This is a basic problem, but my manual is in english, and unfortunatly, those kind of questions are not explained in it.
