 Forum index » Instruments and Equipment » Chameleon
Entity NRPN definition file for Seq-303
roooareee
PostPosted: Tue Oct 06, 2009 9:35 am    Post subject: Entity NRPN definition file for Seq-303 Reply with quote  Mark this post and the followings unread
Hello everyone!
This file allows you to modulate/sequence any 4 Entity parameters per instance of Seq-303. The names used are somewhat truncated, but still intelligible I hope. This is because there are so many parameters to list, and there seems to be a limit of 64kb on .ini files, which this effectively is.
If you've never used Seq-303, it's a standalone midi step sequencer, with lots of cool functions. After several years of being unavailable, the developer has released it in a package with a few other related apps, available here:
http://www.technotoys.com/executables/technotoys-omega.exe
The NRPN file needs to go in \Program Files\Common\Files\Techno Toys folder, then fire up Seq-303, right click one of the default controller tabs, select Soundart Entity from the list at the bottom, and then choose wich of the parameters you want to control, remembering to tick the NRPN box next to each one.
Have fun!
Ruaidhrí
SEQ303_Entity_NRPN.zip
 Filename:  SEQ303_Entity_NRPN.zip
 Filesize:  9.31 KB
 Downloaded:  392 Time(s)
