 Forum index » Clavia Nord Modular » G2 Performances - Experimental
wandering notes
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Dec 15, 2004 8:53 pm    Post subject: wandering notes Reply with quote  Mark this post and the followings unread
Here is a little experiment generating a note sequence algorithmically. The green group of modules in slot C has a pair of RndTrg modules clocked by the main tempo LFO. The probability of each is set to 25% and further modulated by the complimentary outputs of a flipflop. A pair of compare modules toggle the state of the flipflop when the note level goes above or below trip points. The theory was that notes would wander up then down in a cycle. In practice, some statistical anomalies make it do some odd things sometimes.
The other slots contain a variant on the same theme but control delayed feedback PM tones which are fine tuned to the threshold of chaos.
101001001.prf2
random notes
 Filename:  101001001.prf2
 Filesize:  12.06 KB
 Downloaded:  1977 Time(s)
