geometria
Posted: Wed Nov 25, 2009 6:46 pm Post subject:
Nm1 problem with "lost conect" |
hello all
I am a freshman in nord modular but I have a background in synths. This is first time when I have problem with some connection. After I conected modular with pc and i start ediot i see current patch loaded but after few seconds there is a error with such notification:
"lost contact. Open MIDI dialog and enable port again"
Do You know where is problem. I guess that can be a midi interface ( I use Emu Xmid1X1 which is somwhere in this forum recomended ).
Great thanks for any support... |
Wout Blommers
Joined: Sep 07, 2003 Posts: 3714 Location: The Hague - The Netherlands
Audio files: 122
G2 patch files: 11
Posted: Wed Nov 25, 2009 10:00 pm Post subject:
geometria
I assume the Midi interface is in the two dedicated 'PC' in and out.
Is the MN <> PC the only Midi data send and received by the Emu Xmid1X1?
Could there be a Midi Through setting active?
Wout |
geometria
Posted: Thu Nov 26, 2009 4:40 am Post subject:
| I do not think that any other signals are transmitted. This interface is very simple so there is only Midi IN and Midi Out cables and USB , there is no Midi Through. I am not sure how to event check that only midi data are transmitted. Do You know how to check it? |
geometria
Posted: Thu Nov 26, 2009 7:06 pm Post subject:
I also try with XP with background mode and after this was good for 5 minutes. But than lost contact message was displayed again...
I need any help, I can not start fun with modular.. please help  |
Wout Blommers
Audio files: 122
G2 patch files: 11
Posted: Thu Nov 26, 2009 11:35 pm Post subject:
| geometria wrote: | | I also try with XP with background mode and after this was good for 5 minutes. ... | You mean switching to Windows 98 mode in XP? I was thinking about that...
This is a hard one.
Is there by any change more Midi gear or just this one? Maybe some CuBase...?
Wout |
roland kuit
Joined: Sep 29, 2003 Posts: 558 Location: The Hague, The Netherlands
Audio files: 12
G2 patch files: 140
Posted: Fri Nov 27, 2009 4:44 am Post subject:
checked your midi cables? does it work with a sequencer program and your nord? (just midi in then, not pc) maybe you can go to somebody else with your nord and midi device and test it there. or...try an other midi device from somebody else?
i have it occasionaly but it is not common. mostly reastablish the connection works for me. i don't know your midi device. i use a very cheap midiman with free updated vista drivers.
http://electro-music.com/forum/topic-34850.html _________________ TWEAK Last edited by roland kuit on Fri Nov 27, 2009 4:57 am; edited 1 time in total |
Wout Blommers
Audio files: 122
G2 patch files: 11
Posted: Fri Nov 27, 2009 4:52 am Post subject:
| roland kuit wrote: | | ... i use a very cheap midiman with free updated vista drivers. | Where are these availlable, Roland? Midiman MidiSport 2x2 I haven't found XP drivers yet...
Wout |
geometria
Posted: Fri Nov 27, 2009 5:38 am Post subject:
| Currently I have E-mu Xmidi1x1 and yesterday for few minutes was good. I checked cables are fine. The midi interface is new ( from shop and I did not pay yet so I can exchange for other:)) But I would like to be sure what kind of cheap interface is good enough. I have macbook pro with leopard and XP SP2. For me most important for now is to have connection with NM1...thanks for support. |
roland kuit
Audio files: 12
G2 patch files: 140
Wout Blommers
Audio files: 122
G2 patch files: 11
Posted: Fri Nov 27, 2009 5:35 pm Post subject:
Thanks, it works
Wout |
geometria
Posted: Wed Dec 02, 2009 12:17 pm Post subject:
hi all
I have found the problem...do not use or buy E-Mu Xmidi 1x1. I have changed interface for Edirol with new midi cables ( good dyncord ) and now id fine... so thanks guys for help...cheers |
Brom
Posted: Thu Dec 03, 2009 1:21 am Post subject:
Hi, geometria! I confirm the problem with E-mu Xmidi 1x1. It constantly looses it's bloody connection with NM1.
I sold it and bought my new midisport 2x2, and now it's all OK!
Cheers!
| Wout Blommers wrote: | | roland kuit wrote: | | ... i use a very cheap midiman with free updated vista drivers. | Where are these availlable, Roland? Midiman MidiSport 2x2 I haven't found XP drivers yet...
Wout | All drivers are available for downloading at m-audio website, goto: http://www.m-audio.com/forums.html?do=support&tab=driver and choose midisport series, your model and OS.
GL! _________________ Mac Pro 2-dualcore 2Ghz, 3gigs of ram, OSX 10.6, AF-2, TR8-XL, BCR2000, ESI M4U XL, M-Audio Midisport 2x2, Nord micro modular. |
