OmbientMike
Posted: Sat Nov 28, 2009 6:48 pm Post subject:
A Benjolin/ZeitGeist track from Mike Hunter Subject description: Marooned on Planet13 in Sector17 |
I love the sound tracks to old 60`s space flicks...
Here is my take on the genre
http://www.ombient.com/stream/Marooned-on-Planet13%20-in-Sector17.mp3
Hope you enjoy it,
Mike Hunter
Listen to my weekly FM radio show called Music With Space on 103.3FM in NJ or on the web at www.wprb.com each week at 1am EST to 4am EST |
Joined: Apr 03, 2004 Posts: 15138 Location: Netherlands, Enschede
Audio files: 70
G2 patch files: 303
Posted: Sun Nov 29, 2009 8:32 am Post subject:
Nice one! _________________ Jan |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1044 Location: Telford, PA USA
Posted: Sun Nov 29, 2009 12:51 pm Post subject:
Most Excellent Mike!
Forbidden Planet is one of my all time fav's...Very reminiscent. |
Joined: Feb 04, 2005 Posts: 1071 Location: Nottingham, UK
Audio files: 31
laura woodswalker
Joined: Oct 06, 2007 Posts: 253 Location: valley forge pa
Audio files: 9
Posted: Sun Nov 29, 2009 1:56 pm Post subject:
Re: A Benjolin/ZeitGeist track from Mike Hunter Subject description: Marooned on Planet13 in Sector17 |
Are you using both the Benjolin AND the Zeitgeist??
Waaay cool. Love it!!
My son & I are troubleshooting the Zeitgeist. I played this track for him to show what it was supposed to sound like. _________________ The most important music equipment is what's behind the guitar and in front of the computer. |
OmbientMike
Posted: Sun Nov 29, 2009 4:25 pm Post subject:
| laura woodswalker wrote: |
My son & I are troubleshooting the Zeitgeist. I played this track for him to show what it was supposed to sound like. |
It was both the Benjolin and the ZeitGeist. Ihe Benjolin provided the tones and the ZeitGeist provided the cool retro echo sound.
The ZeitGeist, without external input, generates sound really only when the feesbacl is set near or at 100% feedback. Are you feeding it sound?
Glad folks found the track interesting,
Mike Hunter
Danno Gee Ray
Posted: Sun Nov 29, 2009 5:19 pm Post subject:
On my Zeitgeist:
With nothing connected to the input. Zero input.
Feedback pot (2nd from Left) all the way down. = Pure White noise.
Increasing the feedback pot increses oscillations fed into the echo / delay circuit. I can make motorboat noises, spceship engine noises, and if I TWEAK JUST RIGHT...HIGH pitched bleeps and bloops... reverbed to all getout.
All this with ZERO input.
If I connect an input signal, it does not appear to affect the sound at all.
This thing has its own party going and won't let the neighbors in!
I did some rudimentary signal tracing and found that the output of IC2A (pin 1 on the quad opamp) is White noise. |
laura woodswalker
Audio files: 9
Posted: Sun Nov 29, 2009 5:36 pm Post subject:
| Danno Gee Ray wrote: |
Originally it seemed that the left switch on the zeitgeist (pre-post delay) could detune the keyboard sounds. And there were other ways of distorting/modifying the synth sounds. (modulation is the 2nd knob from left in my zeitgeist.) I can't explain its exact function because I'm a newby to electronics. I just labeled the knobs/switches the way Rob told me.
Now it mostly just shrieks & howls. Well, what did I expect, it IS an 'Alien transmission module'... just different aliens now!  _________________ The most important music equipment is what's behind the guitar and in front of the computer. |
OmbientMike
Posted: Tue Dec 01, 2009 7:59 pm Post subject:
What a ZeitGeist sounds like |
| Danno Gee Ray wrote: | On my Zeitgeist:
Odd...the input signal should be "echoed." After all, the zeitgeist is based on an "echo" chip. There is a switch that enabled the light sensor and a switch that mixes the input signal with that of echoes. In the other position, the original signal is muted and only the echoes of it are left.
If no imput is connected and the feed back (the second knob from the left) is turn up high or completely, then the noise in the circuit is echoed and build up over time into that strange noise you hear.
If the turn the two knobs on the far right, you are altering the length of the echos from short on the left to long on the right.... as the echo time increases the sounds recorded "slow down" and thus, drop pitch. If turning from a long echo to a short the pitch increases in pitch.
If the two knobs are increased high enough, the echoes go beyond the parameters of the chip and cacophony ensues until it completely goes out and the sound disappears altogether.
Hope this description helps you understand how the unit sounds... I can create a youtube video showing this visually and with soundif this is useful to you. I can also do this for the benjolin for comparison sake.
Just let me know, _________________ Mike Hunter
Danno Gee Ray
Posted: Tue Dec 01, 2009 8:25 pm Post subject:
That might be very useful Mike.
My Benjolin seems to be working OK. It's the Zeitgeist that has a trip of it's own going right now. It's almost as if the "Clock" signal within the unit is too high a level and needs to be attenuated some. I was thinking of severing the link between pin 1 and 5 of the Quad Op amp and inserting a variable resistance in between to see if that would tame the thing a little.
A video would help me to guage how that might be working.
Thanks. |
Rob
Joined: Mar 29, 2004 Posts: 563 Location: The Hague/Netherlands/EC
G2 patch files: 109
Posted: Mon Dec 07, 2009 7:01 am Post subject:
The Zeitgeist has some design flaws, mostly to do with the CMOS reel-to-reel opamp that seems to have a will of their own. Replacing the CMOS opamp with a LM324 does help in cases, but there are some more things that need a little change in the design for a LM324. Basically the virtual ground for the opamps isn't always as stable as it should be and would be with the FET opamps like the TL074A I normally use. (The CMOS opamp was recommended by the Texas Instruments distributor as a problem-free reel-to-reel, low voltage, low power alternative for the TL074A. I fully relied on their advice, just as I had so little time to develop the Zeitgeist...)
In contrast to the Benjolin design, which has been a proved circuit over quite some years, I didn't have the time to really test the Zeitgeist design thoroughly. I built four Zeitgeists just prior to the workshops and all worked fine, so I thought all was ok. I am sorry that the Zeitgeist behaviour is a bit more mysterious as it was meant to be, and sometimes just gives up...
I am redesigning the Zeitgeist to make it as reliable as the other stuff I make. Until then no more Zeitgeist workshops...
/Rob |
Danno Gee Ray
Posted: Mon Dec 07, 2009 8:20 am Post subject:
Just so you know, Rob,
I'm not upset with mine at all. It is still a cool noisemaker.
When you get it sorted out, It would be nice if I could buy a new circuit board from you for the new design. Good luck,
Dan |
laura woodswalker
Audio files: 9
Posted: Thu Dec 10, 2009 5:33 am Post subject:
| Rob wrote: | The Zeitgeist has some design flaws
/Rob |
Hmmm, well that kinda sucks, what do I do with a non-functional Zeitgeist? Maybe take out the electronics and stick a bunch of LEDs in the box??
Oh yeah.... I don't need it anymore....I just got a Korg Electribe!!!!! It can make just as many weird sounds as the Zeitgeist... maybe I'll upload some samples tonite! _________________ The most important music equipment is what's behind the guitar and in front of the computer. |
