2009 Build Pictures
Page 14 of 16 [399 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14, 15, 16 Next
davemoog
PostPosted: Thu Dec 24, 2009 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I've built - took most of the year but sounds pretty great (I think:-)
More details at http://minimalist.davidleith.com/DeitzModSynth6.html
Module 1 (Top to Bottom)
- EMS Noise/Colour, Buchla VC Lag (3 preset times plus external VC), CGS Slope/Sensitivity
- Buchal 208, output 1 prewired to lag thanks to vtl5c3
- Buss mixer/attenuvertors, YuSynth Dual Min/Max (1/2)
- ARP 4027 VCO/LFO with External Sync and Lo-Hi Ranges, triangle, saw, pulse with external PM modulation
- ARP 4014 Ring modulator thanks to Bergfotron
Module 2
- Dual Moog 9001 VCO with sine, triangle saw and pulse with external PM modulation thanks to T, C and P.
Module 3
- Dual Moog 911/911A Envelope generator with delay & cycle mode (10 volt gate), Multiples, YuSynth Dual Min/Max (1/2)
Module 4
- ARP 2500 1047 MUltimode Filter Resonator
- ARP 2600 4013 (epoxy) VC Ladder Filter,
- ARP 2600 4019 (epoxy) VCA
- Matrix Mixer with switches and External Preamp (ARP 1047)
 Filesize:  95.18 KB
 Viewed:  480 Time(s)
 Filesize:  86.48 KB
 Viewed:  378 Time(s)
Danno Gee Ray
PostPosted: Thu Dec 24, 2009 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Utterly awesome!
adambee7
PostPosted: Fri Dec 25, 2009 3:35 am    Post subject: Reply with quote  Mark this post and the followings unread
man thats sexy. nice job. Very Happy Very Happy
TekniK
PostPosted: Fri Dec 25, 2009 3:59 am    Post subject: Reply with quote  Mark this post and the followings unread
agree,one of the nicest pieces i seen,saw it before on some site or blog but din't know it was from u!
Funky40
G2 patch files: 5
PostPosted: Sat Dec 26, 2009 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
beside that it looks good it seems to be a very well thought out layout spacewise.
Finally function counts, not optics.
hey, all lovely work what you guys show Cool
glacial23
PostPosted: Sun Dec 27, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
I filled up my Frac system the other day - I started it in late August:
glacialcommunications.com
neandrewthal
PostPosted: Mon Dec 28, 2009 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't posted much in this thread because I hardly got anything done in the first 8 months and then scrambled to complete as much as possible when the school year ended. Everything in the top cabinet is from 2009. I hope to finish it in 2010.
Fritz Jerkster/Double Well/DGTS&H, Topp Buchla Quad Function Generator, CGS Modulo Magic/CV Cluster:
Haible Living VCOs, Tellun Doomsday Machine
Dual Flight of Harmony plague Bearer, Yusynth Fixed Filter Bank, Haible Interpolating Scanner:
CGS Triple Quad Logic Gate, CGS Master Divider/Dual MFOS Quantizer/Dual Tellun Lag Processor, Dual Fritz Teezer:
CGS Steiner Filter/Fritz Threeler, Fritz Quad All in EG:
Some guts:
TekniK
PostPosted: Mon Dec 28, 2009 4:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
some great panel designs here.
love the diana V panel.
patchdub
PostPosted: Mon Dec 28, 2009 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
absolutely awesome cabinet neandrewthal!!!
peng
PostPosted: Mon Dec 28, 2009 11:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just finished this one.
Blacet Time machine to Modcan refit:
I hope the owner will be as happy receiving this as I was (finally) finishing it!!!
Two different Wave Multipliers with a bit extra and a Burst Generator:
Unfortunately, all these modules left my possession as soon as they were finished. It was hard to say goodbye Smile
p.
Wish I had more but the metalphoto place screwed up my prototype!
Ohhh, I need an aspirin.
 Filesize:  132.52 KB
 Viewed:  22188 Time(s)
 Filesize:  180.9 KB
 Viewed:  345 Time(s)
 Filesize:  100.82 KB
 Viewed:  331 Time(s)
 Filesize:  104.71 KB
 Viewed:  311 Time(s)
xpmtl
PostPosted: Tue Dec 29, 2009 4:03 am    Post subject: Reply with quote  Mark this post and the followings unread
i really like those. the time machine panel is a pure beauty. good job peng
http://sdiy.xpmtl.net
TekniK
PostPosted: Tue Dec 29, 2009 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
great look peng!
PostPosted: Wed Dec 30, 2009 2:12 am    Post subject: Reply with quote  Mark this post and the followings unread
+1! Gorgeous!
/Stefan
jnuaury
Audio files: 9
PostPosted: Tue Jan 05, 2010 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
finished my gdeip voltage controllable video synthesizer around 7AM on 12/31/09
and some videos of my testing it out
http://www.youtube.com/watch?v=CW2iNaaQrJc
http://www.youtube.com/watch?v=zBesShRekR4
Sebo
PostPosted: Tue Jan 05, 2010 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I finished my WASP VCF a few weeks ago. I added 2 extra gain stages at the output
as the level was a little weak compared with other modules. One stage amplifies X2
the Distortion out, and the other amplifies the main output X2, so when the
Distortion is engaged I get a X4 gain.
I will post a general picture of the actual state of my modular soon.
 Filesize:  159.86 KB
 Viewed:  292 Time(s)
You can see the little board glued to the main PCB.
 Filesize:  178.03 KB
 Viewed:  300 Time(s)
Sebo
My Music:
peng
PostPosted: Wed Jan 06, 2010 2:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Antimon wrote:
+1! Gorgeous!
/Stefan
Thanks guys!
The Time machine and the Wave Multipliers have modified circuits.
The TM CV VCA is modified so that the envelope follower, LFO, and External Input are pre VCA instead of post VCA. Originally, only the LFO goes thru the VCA.
The Wave mults have a boost switch that pushes the module into some intense overdrive. Plus a bunch of component value tweaks.
I'll try and get up a couple posts documenting the mods and I'll put them in their relevant sub forums.
p.
adamon
PostPosted: Wed Jan 06, 2010 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
The caliber of work in here is amazing (just plain ridiculous at times!)! I'm almost embarrassed to post my stuff, but I suppose this will be a good benchmark to compare to at then end of 2010.
Here's how my system ended up at then end of the year. This past year was really the beginning of it all for me as far as diy synth stuff is concerned, so most of it is fairly basic. Most of the modules are lunetta-based stuff (various 40106 oscillators, some dividers, 4077 ring mods, and others...), but I got a few op-amp based modules in as well (some lfos and a couple of filters). Many thanks go out to everyone in the lunetta forum for all the inspiration!
I just got my first volumes of electronotes, so it's on in 2010!
Also, I built a little synth for emraldadrift as a gift a few weeks back (probably my favorite build of the year!).
Adamon's modular at the end of 2009
 Filesize:  1.02 MB
 Viewed:  312 Time(s)
Emraldadrift's holiday synth built by Adamon
 Filesize:  1.52 MB
 Viewed:  288 Time(s)
www.soundcloud.com/adamon
ErichBreakfast
PostPosted: Thu Jan 07, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
That module looks great. Where did you get those knobs? I was thinking about using some knobs like that on my next sequencer project.
RF
Audio files: 28
PostPosted: Thu Jan 07, 2010 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Love the plexi in the suitcase adamon! Nice job.
bruce
www.sdiy.org/rfeng
The Bad Producer
PostPosted: Thu Jan 07, 2010 10:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I totally agree, every time I look in here I'm newly amazed and inspired! (your work included adamon - looks great!)
They look like Davies 1900 clones available from Smallbear in the USA, either in phenolic:
http://www.smallbearelec.com/Detail.bok?no=707
or ABS:
http://www.smallbearelec.com/Detail.bok?no=831
or in lots of different colours:
http://www.smallbearelec.com/Detail.bok?no=727
Charlie
jnuaury
Audio files: 9
PostPosted: Thu Jan 07, 2010 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks and yes, they are the serge-alikes from smallbear.
if you are talking about the three knobs on top...
one of my friends gave me about a hundred 1k pots with 1/8" shafts that have those knobs on them
az/gde
YouTube
Sebo
PostPosted: Sat Jan 09, 2010 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi:
Here is a picture of my modular as it was at december 2009 (now it have
a new module, jeje).
Top row:
MIDIbox CV
3 x Yusynth VCOs
Papareil Synth Labs Quantix-8
Yusynth Mixer
Yusynth ADSR
Yusynth MiniMoog VCF
Yusynth Synthacon VCF
Yusynth ADSR
Yusynth VCA
Bottom row:
Yusynth LFO
Yusynth Dual Slew
Sebo Buffered Multiple
Yusynth Noise/Sample & Hold
Frontpanel for Yusynth Sawanimator (is finished now)
Yusynth Dual Ring Modulator
Yusynth Juergen Haible Wavefolder
3 empty units
Yusynth VCA
Yusynth ADSR
Frontpanel for Yusynth EMS VCF (to be completed soon)
Juergen Haible/Fonitronik WASP VCF
Yusynth ADSR
Yusynth VCA
 Filesize:  213.97 KB
 Viewed:  345 Time(s)
Sebo
My Music:
Funky40
G2 patch files: 5
PostPosted: Sun Jan 10, 2010 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Charlie
+1 on all
love that little box too adamon. very stylish !
TekniK
PostPosted: Mon Jan 11, 2010 5:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sebo wrote:
Hi:
Nice system!
Sebo
PostPosted: Mon Jan 11, 2010 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Sebo wrote:
Hi:
Nice system!
Thanks!!!
Sebo
My Music:
