How to generate Perlin/Fractal noise?
Page 1 of 1 [2 Posts]
anigbrowl
G2 patch files: 5
PostPosted: Thu Dec 31, 2009 1:07 pm    Post subject: How to generate Perlin/Fractal noise? Reply with quote  Mark this post and the followings unread
I've been getting into noise lately and I'm particularly interested in fractal noise, sometimes also known as brown noise. This is like pink noise but characterized by a 6dB rolloff in increasing frequencies. In computer graphics Ken Perlin has earned an oscar for his work on noise, which can be used to simulate realistic-looking textures for anything from clouds to landscapes.
The basic technique involves mapping a gradient (in 1 dimension, this would be our trusty saw wave) to a pre-calculated set of random values (ie a wavetable) and then doubling the frequency and adding the result back to itself.
I've been experimenting with various strategies for making interesting kinds of crunchy-sounding noise (an example is enclosed for your listening pleasure; you might want to turn down the volume) but I'd like to take a more mathematical approach. Anyone done any work int his area?
resistor AB.pch2
 Filename:  resistor AB.pch2
 Filesize:  1.51 KB
 Downloaded:  476 Time(s)
jamos
G2 patch files: 35
PostPosted: Thu Dec 31, 2009 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try the circuit here:
http://www.electro-music.com/forum/topic-4823.html
This generates a fractal based on the logistic equation. Clock it at audio rates with an oscillator and you're on your way.
JuneSolstice2013
