opg
Joined: Mar 29, 2004 Posts: 954 Location: Berkeley, CA, US
Posted: Tue Feb 21, 2006 7:15 am Post subject:
FLechdrop wrote: | http://www.modplug.com
This tracker has a rather more Windows-like style, which makes it somewhat easier for me to get the hang of things. |
This is the first tracker I used. It made learning how to use a tracker easy! |
Static Strobe Emitter
Audio files: 243
Posted: Fri Feb 24, 2006 5:37 am Post subject:
Hehehe. |
Im one of those poor guys who cant work in "Window Like" environments.
I once downloaded MadTracker and sat with it for 2 minutes and
the last thing i remember thinking before I pressed the Exit button
was "This looks more like Microsoft Word than a tracker"
:X |
opg
Posted: Fri Feb 24, 2006 6:40 am Post subject:
Yes. Trackers are for us young, motivated business professionals. Want me to give you the most used notes for my 4-minute song at 140 bpm? Let me just pull up the tracker and enter the formula. I'll then copy the data into Excel and create a 3D pie chart.  |
Audio files: 243
Posted: Fri Feb 24, 2006 6:45 am Post subject:
aRrgghhh!! |
GAAAAAAAAAAAAAAAAAAAAAAAAAAH!!!
I rather sit with my first created AMOS Basic tracker (I think i named it Das Mjuuusich!!" which
used the "Bell / Noise" commands to produce sounds !
it did have a save/load function though =o |
opg
Posted: Fri Feb 24, 2006 7:25 am Post subject:
Re: aRrgghhh!! |
Static Strobe Emitter wrote: | GAAAAAAAAAAAAAAAAAAAAAAAAAAH!!!
Hey, where can I get that? |
Kassen
Posted: Fri Feb 24, 2006 8:45 am Post subject:
Ok, fooled around with Milky last night but it seems that you can't write notes while the music is running. Is htat true? _________________ Kassen |
opg
Posted: Fri Feb 24, 2006 11:21 am Post subject:
Kassen wrote: | Ok, fooled around with Milky last night but it seems that you can't write notes while the music is running. Is htat true? |
That sounds about right. I haven't tried Milky or any of the newest trackers, but that's been my experience. I can see how that would annoy a lot of people who are used to knob-tweaking or playing along with the tune. Imagine a tracker as like drawing a picture on the computer one pixel at a time (but being able to cut/copy/paste large chunks as well). You can come up with really detailed, complex stuff, but it can be really tedious. Of course, there are many trackers that support VST effects plugins.
What about VST instruments? Hmmm.... |
Kassen
Posted: Fri Feb 24, 2006 1:25 pm Post subject:
Erm, yes, erm....
But if you are building a image pixel by pixel you probably aren't doing that with your monitor turned off, I'm realy not so sure about this. Does renoize support inputting data while the track runs? _________________ Kassen |
Audio files: 243
Posted: Fri Feb 24, 2006 1:56 pm Post subject:
hey :/ |
milky does support recording notes while having "Rec" button pressed..
....atleast in my version....however, I never use it :X
i never even use the play function on Sequencers, i always
click out each stuff with the mouse buttons D |
Kassen
Posted: Fri Feb 24, 2006 2:27 pm Post subject:
Hmmmm. Perhaps I'm missing something. I should spend more time with it. _________________ Kassen |
opg
Posted: Fri Feb 24, 2006 2:35 pm Post subject:
IMO, I wouldn't use trackers that can handle HQ audio and big VST plug-ins. The older PC trackers, as well as the Gameboy and C64 trackers have their own sound, obviously - but I like the way they handle WAV files and how "glitchy" the Attack and Release of the notes are. It's more of a retro thing for me, as always..... |
Audio files: 243
Posted: Thu Mar 02, 2006 7:40 am Post subject:
Tracker elites! |
I just have to post this legendary track made by Dreamer.
The track itself is kinda simple hardcorish. you have to look
at the "code" while playing this track to understand how wonderfully
handcrafted it really is.
Just take the part when one track is going forward and
another one is going backwards at the same time.
this IS impossible to actually create, but thanks to smart
pattern and position jumping he makes it look like it
actually does.
truly amazing. Ill provide both a video capture of the song while playing it,
and the original file for the trackers to download. enjoy tracking insanity :X
Most players will crash or behave strangely when playing this module,
so be sure to run it through an complete FT2 compatible player/tracker.
Original Module
http://jaedernaub.ath.cx/blackqueen.zip
Video Capture (DivX 6.0)
http://jaedernaub.ath.cx/black.zip |
Kassen
Posted: Thu Mar 02, 2006 2:04 pm Post subject:
WOW!
F*** me, that's crazy! _________________ Kassen |
Joined: Jan 31, 2003 Posts: 17897 Location: Allentown, PA
Audio files: 147
Posted: Thu Mar 02, 2006 2:41 pm Post subject:
That is amazing. I don't understand it, but it is amazing.  _________________ --Howard
my music and other stuff |
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Mon Mar 06, 2006 1:15 am Post subject:
I was checking this out today: Aodix by Arguru (the same guy that made all those great generators and effects for Buzz in 1999/2000)
First truly revolutionary tracker I've seen since Buzz. The whole program is nothing but the most optimized, pure VST host and sequencer I've ever seen, all packaged into a completely reoworked tracker environment. It's so clean and optimised it's the only VST host I've ever used that allows me to set my latency to the lowest my card will go glitch free. There's no inbuilt sampling, the whole thing is a tracker based sequencer for a modular VST host.
It's basically a tickless tracker - there is a grid, but you can move notes around in time freely (or quantize them if you wish), zoom in and out, have multiple notes on the same beat etc. You can also trigger notes from different vst instruments on the same channel (using different note parameters), automate synths/effect effortlessly etc.
Best of all, running behind it all is a truly modular VST host. Clearly displayed are the inputs and outputs (including midi) when you add an instrument/effect, so not only can you route anything to anything else, you can also route more than one object to the same input ala Buzz (complete with gain controls on the "cables").
And then you've got the system for arranging patterns which I won't bother trying to explain. Amazing stuff, makes me question my purchase of Cubase SL3 a couple of months ago (only just ) |
Kassen
Posted: Thu Apr 13, 2006 1:04 pm Post subject:
Reporting back.
After I got fed up with Milky for not looping while I was writing in a way I could understand I installed Renoise. Renoixse works for me, in fact I was up and tracking within a few hours, then wrote silly stuff in it untill dawn, slept for a few hours and went back.
I think I'll get a registration soon. _________________ Kassen |
Audio files: 243
Posted: Sun Aug 27, 2006 4:07 am Post subject:
Tracker Tutorials! Subject description: Weehaa! |
For the none-trackers who wish to see how a tracker-guy works,
you can download Tracker tutorial videos now at http://www.milkytracker.net/download.html
=D *made by strobe ofcourse*.
the "Milky Usage" video is made by Kmuland, "Sine Crafting" is Rainas work, the rest is me, and is mostly covering chip basics  |
Kassen
Posted: Sun Aug 27, 2006 8:29 am Post subject:
Very cool, Strobe!
After my brief run in with trackers I switched to making my own sequencer in ChucK but I stole a lot of the bits of how trackers work for that. I'll be sure to check your tutorials hoping for more stuff to steal!
I mean... get inspirered by, of cource.
:¬) _________________ Kassen |
kruhft
majutsu
Posted: Sun Nov 26, 2006 8:44 am Post subject:
seraph wrote: | you guys will have to explain to me what is the advantage of using a tracker versus a sequencer because I don't get it, maybe I am simply too old for this ****  |
actually, you got it backwards, seraph. you are too YOUNG for this. trackers are the oldest form of computer music tools, the very first ever. There were the first tools ever for the most primitive and earliest computers. c-64, amiga etc only had trackers. and before any of us had a desktop they were the only way of having music for games when games were played on big monsters in the late 60s early 70s. Essentially the very first adaption of hardware samplers for the early computer were called trackers. synthesis, max, the early music programming languages at IBM all required more computer power to be developed. True trackers are nothing but computer based samplers. They hold nostalgic value for those of us with roots in the beginning of computer music. Rap in the early 70s, gflash, krs, etc were all sampler acts. Lofi 8bit sampling takes you back to the beginning of it all.
i love it. i love the revival. guys like venetian snares (who used octamed and amiga trackers ONLY on his earliest and BEST albums) show what can be done with this still untapped art form.
p.s. on linux i think milkytracker - a perfect clone of the old ft2 -- is the best. i like soundtracker, but the sound is not like a real old tracker. milky delivers that retro, clean chip sound to my ears. _________________ All phenomena are atoms in association and dissociation. |
Sam_Zen
Posted: Sat Jan 30, 2010 6:35 pm Post subject:
Never noticed this "Lofi" section before on the EM forum, because I thought it was about toys and bended things.
To my surprise there are also things about tracker modules here.
Reading the conversation I notice that tracking is seen as something nostalgic made with low quality samples.
This has been the past, but things have been changed.
I started with FT II some 20 years ago and when windoze came, I soon switched to ModPlug Tracker.
The author stopped the work, but offered the source, so since then an open source variant has been developed by others.
The present ModPlug is a very powerful tool to compose with.
8-bit 8 kHz samples are still possible of course, but it can also handle a 16-bit 44kHz stereo WAV of 3 minutes..
It can be a host for VST(i) plugins as well.
More info can be found here
A few examples of recent pieces (OGG format) :
No Odds - 5:19
Scattered Flow - 4:52 _________________ 0.618033988 |
Audio files: 147
Posted: Mon Feb 01, 2010 4:59 pm Post subject:
Thanks for the update about trackers. I like your tracks. Tracker music has a very nice quality to it that I like. I would like to learn how to use them. _________________ --Howard
Sam_Zen
Posted: Mon Feb 01, 2010 6:43 pm Post subject:
As mentioned here before, one has to learn it indeed. But the reward is a very detailed control over sound and composition.
There's the ModPlug Wiki.
And recently, one of the members of the MP forum is working on an offline manual, still beta.
Since the introduction of the VST plugins a new generation of trackers has come, the number of people using samples only is decreased.
If one wants to start tracking, then it's probably a choice one has to make.
Plugins or samples, both with their own specific techniques, although the notations in the score are mainly the same. _________________ 0.618033988 Last edited by Sam_Zen on Mon Feb 01, 2010 7:29 pm; edited 1 time in total |
nobody
Posted: Mon Feb 01, 2010 7:26 pm Post subject:
majutsu wrote: |
p.s. on linux i think milkytracker - a perfect clone of the old ft2 -- is the best. i like soundtracker, but the sound is not like a real old tracker. milky delivers that retro, clean chip sound to my ears. |
I found milky and soundtracker in Portage on Gentoo. I'm going to try those out! |
Sam_Zen
Posted: Mon Feb 01, 2010 9:04 pm Post subject:
A nice database by Jikoo about trackers for all kinds of platform can be found here - also about Chiptunes
If one has to learn about making tracker modules, it's very useful to d'load existing pieces to see how it's done, with the codes etcetera :
A huge collection with all kinds of formats can be found at Modland
My own collection of 'oldskool' modules (XM or MOD) by others can be found here.
Besides the editors, it's nice to have a versatile player of the module formats on its own.
Windoze : XMPlay - Mac : XimpleMOD _________________ 0.618033988 |
