4-point linear interpolation
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Apr 07, 2010 5:20 pm    Post subject: 4-point linear interpolation
Subject description: linear upsampling from 24k controlrate to 96k audiorate
This building block upsamples blue (24k) controlrate signals to red (96k) audiorate signals via 4-point moving average linear interpolation. I used this in the patch "PolyGranuSyn_XL" to convert controlrate sawtooth LFOs to audiorate, for sound quality reasons.
The logic section to the left provides 4 consecutive logic pulses at 96k. So you only need this circuit once if you want to convert more than one signal. Just use the 4 S/Hs and the mixer and connect the trigger pulses (it doesn't matter in which order).
Perhaps this is of use to someone.
cheers
t
4ptLinInterpolTK.pch2
 Filename:  4ptLinInterpolTK.pch2
 Filesize:  1.07 KB
 Downloaded:  1144 Time(s)
