Rompler Air Pad
Page 1 of 1 [4 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Jan 15, 2005 10:54 pm    Post subject: Rompler Air Pad Reply with quote  Mark this post and the followings unread
Hi all,
The result of playing around with the noise osc & comb filter. The idea was to create an airy or breathy sound that falls somewhere between pitched and unpitched noise, like the 'air' artifacts in a rompler sound.
I found that for this type of sound, the noise oscs & comb filter don't have to track the keyboard 100% to get the desired effect. In fact it sounds better with maybe 30-50% tracking, so the air effect sounds 'right' across a larger key range.
Two variations, no knob assignments. Enjoy!
Rompler Air Pad.pch2
 Filename:  Rompler Air Pad.pch2
 Filesize:  4.37 KB
 Downloaded:  915 Time(s)
Dave Peck
Audio files: 150
PostPosted: Sun Oct 07, 2007 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
just been playing with this, it's very nice and quite useful as 'flute' replacement
music | adventures in sound
Falk
G2 patch files: 29
PostPosted: Wed Feb 27, 2008 1:48 pm    Post subject: Air Rompler on a diet Reply with quote  Mark this post and the followings unread
Hi Dave.
I have tried to put your wonderful patch on a diet. Less oscillators, less FX, well ... less everything.
3 variations and knob-assignments.
Instead of tremolo on the wind I modulate the feedback on the comb filter which works rather well (IMHO).
I hope you don't think I mutilated it to much.
Regards
/Falk
AirRomplerLight.pch2
Air Rompler Pad on a diet, less of everything but under 50% CPU
 Filename:  AirRomplerLight.pch2
 Filesize:  3.05 KB
 Downloaded:  645 Time(s)
Falk
G2 patch files: 29
PostPosted: Tue Mar 04, 2008 10:58 am    Post subject: I really should have copied the right bits.... Reply with quote  Mark this post and the followings unread
Hello all.
After some more thought and listening I made a new version. The band reject filter was really needed so I had to remove the chorus from the VA. I put in some random panning instead and added back the chorus to the FX.
The other major mistake I made was to filter the feedback on the delays, made a large change to the sound when I removed that.
Memo to self: When copying davep, copy the right bits and pay attention to the details Very Happy
Is it good enough for G2 Patches - Completed or should we petition davep to copy the original there?
Regards
/Falk
AirRomplerLight2.pch2
4 variations, knob assignments and new, improved copying of davep's Air Rompler Pad but shoehorned into 50% CPU for VA
 Filename:  AirRomplerLight2.pch2
 Filesize:  3.62 KB
 Downloaded:  688 Time(s)
