laura woodswalker
Joined: Oct 06, 2007 Posts: 437 Location: phoenixville pa
Audio files: 12
Posted: Tue Aug 31, 2010 2:19 pm Post subject:
Setup questions |
I am getting ready for my Very First Performance! I timed my setup time... approx 2 minutes. Then I looked at the schedule and was relieved to find that there seems to be 1/2 hour between acts. Is that correct? Hope so.
Technical issues: does the 'house' have long enough cables to reach whatever mixing board you're using? Do you have powerstrips or should I bring my own? What else should I bring?
My current setup is very low-rent. It's on my bedroom desk.
Laura _________________ The most important gear is the brain behind the instrument. |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Tue Aug 31, 2010 9:31 pm Post subject:
If you read the "guidelines for performers" email that was sent to all particpants, all of these questions were answered there.
Yes, there is at least 1/2 hour between sets. That time includes take down for the previous set, and also sound check. So we ask that you pre-stage your rig as much as possible earlier than that.
You should bring your own cables to connect to the mixer (or snake, if you're in the theater). 20 ft is recommended, but we can probably deal with shorter lengths.
You should bring sufficient power strips to plug in all of your gear. _________________ www.gregwaltzer.com |
laura woodswalker
Audio files: 12
Posted: Wed Sep 01, 2010 3:51 am Post subject:
egw wrote: | If you read the "guidelines for performers" email that was sent to all particpants, all of these questions were answered there. |
Hi Greg,
I don't think I got that email.
thanks
laura _________________ The most important gear is the brain behind the instrument. |
laura woodswalker
Audio files: 12
Posted: Wed Sep 01, 2010 1:35 pm Post subject:
You should bring sufficient power strips to plug in all of your gear. |
Thanks for your help, Greg!
20' cables are so expensive...! I have lots of short cables & a stereo cable (single to double) that is about 5' long. What's the best way to convert it to 20'? Buy a few couplers and plug my shorter cables into the couplings? Would I lose a lot of sound quality that way? _________________ The most important gear is the brain behind the instrument. |
Acoustic Interloper
Joined: Jul 07, 2007 Posts: 1943 Location: Berks County, PA
Audio files: 81
Posted: Wed Sep 01, 2010 4:10 pm Post subject:
laura woodswalker wrote: | egw wrote: | If you read the "guidelines for performers" email that was sent to all particpants, all of these questions were answered there.
20' cables are so expensive...! I have lots of short cables & a stereo cable (single to double) that is about 5' long. What's the best way to convert it to 20'? Buy a few couplers and plug my shorter cables into the couplings? Would I lose a lot of sound quality that way? |
Laura -- find me Saturday morning likely somewhere near the drum circle and I'll lend you a pair of cables.
EDIT: What's your output look like, 1/4", XLR or other. 1/4" and XLR I got. _________________ When the stream is deep
my wild little dog frolics,
when shallow, she drinks. |
laura woodswalker
Audio files: 12
Posted: Wed Sep 01, 2010 5:11 pm Post subject:
Acoustic Interloper wrote: |
EDIT: What's your output look like, 1/4", XLR or other. 1/4" and XLR I got. |
Hey Acoustic!
I use 3 audio outs (one Mono instrument, one stereo). I found one 20' cable around the house. That leaves 2 for the stereo.
THANKs so much for your offer. I might stop at Sam Ash tomorrow & see what a pair of 20's would cost me. But I'll keep your offer in mind.
Are you the Banjo guy?
Acoustic Interloper
Audio files: 81
Posted: Wed Sep 01, 2010 5:23 pm Post subject:
Laura |
Yep! See you soon. _________________ When the stream is deep
