LetterBeacon
Posted: Mon Sep 13, 2010 4:24 am Post subject:
VCO Calibration Tool |
Now I've got my ARP oscillators built and working I now want to scale them properly. I was thinking of building the MFOS Calibration Tool below but I have a few questions:
- I should be able to power this off my +/-15V modular supply, right?
- If I add more 10K resistors and adjust Point TPA so it reads 7V, I should be able to calibrate from 0-7V, right?
Schematic came from here:
http://www.musicfromouterspace.com/analogsynth/August2003VCO.html
slacker
Posted: Mon Sep 13, 2010 10:10 am Post subject:
Yeah that should work fine, except that, with the original values at 15 volts the pot will only let you adjust between about 5.6 and 6.8 volts. If you change the 68k for a 51k then the pot will have a range of about 6.5 - 8 volts.
You might get away with a 47k instead but that puts the bottom end quite close to 7 volts. |
LetterBeacon
Posted: Mon Sep 13, 2010 4:02 pm Post subject:
Brilliant, thanks very much for that!
What equation did you use to work out the voltage range? |
Strazdas
Joined: Apr 21, 2010 Posts: 42 Location: Kaunas, Lithuania
forbin
Joined: Jan 29, 2009 Posts: 120 Location: Fremantle, Australia
Posted: Wed Sep 15, 2010 5:25 am Post subject:
| An approach that I use (but I do access to the hardware) is to use a PC and a MIDI feed from a Soundblaster compatible GamePort to drive my MIDI->CV and then get either an Oscilloscope or DFM to measure the frequency. I then get the script to read in the frequency value and work out the slope of the curve and hence it's calibration. I am thinking of getting the soundcard to pull in the audio and do a zero crossing measurement to work out the frequency to avoid the CRO/DFM. It is relatively slow as it takes ~ 3 min to do a sweep but you do get a pretty accurate cal! I have also run the script over a weekend to see how the Tempco is coping... I really need a digital temperature sensor... I would like to clean it all up and make a PC application to do it... Not sure if there is any interest? One thing that it did show up though is that my MIDI->CV DAC was fairly wobbly and then I ended up putting in a DMM to take out that variable... all got a bit like a Science Fair experiment at the end... |
LetterBeacon
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Mon Oct 04, 2010 8:12 pm Post subject:
Power conditioning is always nice...not sure if it's needed but I'd do it anyway.
Did you build it and did it work for +/-15V? I'm in need of the same thing. |
LetterBeacon
Posted: Tue Nov 23, 2010 1:48 pm Post subject:
Sorry for the extremely late reply!
I've literally just got round to building the stripboard layout and it all seems to work!
I didn't put power conditioning on as I thought I'd do as Ray suggested and put crocodile clips on the power wires so I can piggy back off the VCO's power. |
emdot_ambient
Posted: Tue Nov 23, 2010 2:12 pm Post subject:
| Cool. Sounds like something I need to build. |
emdot_ambient
Posted: Tue Nov 23, 2010 2:14 pm Post subject:
| Oh...did you actually build yours to do 7 octaves? Your stripboard diagram shows an output to Position 8, but the MFOS schematic doesn't actually use that position, it maxes out at Position 6. Adding 2 more 10K resistors to Postion 7 and 8 would give you 7 octaves total. |
LetterBeacon
Posted: Tue Nov 23, 2010 3:02 pm Post subject:
| I actually built it to go up to 8 octaves in the end. I soldered all the resistors on the back of the rotary switch. |
