 Forum index » Instruments and Equipment » Arturia Synths
ArtFfct.dll problem....
DES
PostPosted: Fri Sep 17, 2010 7:41 pm    Post subject: ArtFfct.dll problem....
Subject description: How to fix...
Just purchased Jupiter 8v and Prophet V to add to my collection. Install went sort of smooth. I bought these using the Buy One - Get One Free deal - the Prophet was the freebie.
So I went to download it as indicated and the version downloaded was 1.2.1 which is strange since 2.0 was out. Installed it anyways and the eLicenser didn't like it so I went to the update section and downloaded/installed the version 2.0 Prophet - working fine.
I figure might as well uninstall the 1.2.1 version since it didn't work. Once I did that I started Kore 2.11 up to do some playing and when ever it scanned an Arturia synth I got an Alert! message saying that the file ArtFfct.dll didn't exist. Once Kore finished scanning I tried loading ARP 2600v to see what would happen and the Alert! message kept coming up repeatably until it crashed the program.
After searching around the Arturia forums I found information that the file in question needed to be installed (in Windows) to the C:/Windows/System32 directory. It was probably deleted when I uninstalled the 1.2.1 version of Prophet V.
The fix: Just re-install one of your Arturia synths. Make sure that if you have any custom programs that you back them up first.
All the Arturia synths seem to be happy now. Jupiter seems to use a lot of CPU though...
www.davesneed.com
