  bingsatellites Mostly Ambient
Variable clock divider any ideas?
Page 1 of 1 [19 Posts]
3phase
G2 patch files: 138
PostPosted: Fri Jun 04, 2010 8:16 pm    Post subject: Variable clock divider any ideas? Reply with quote  Mark this post and the followings unread
i would like to have a clockdivider with modulation input..
any ides how to patch that?
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 1:04 am    Post subject: Reply with quote  Mark this post and the followings unread
treid it with tims up down counter. not sur e yet if it does the wright thing..
i try to simulate this module...
http://www.schneidersbuero.de/forums.html?sect=products&lang=de&product=4ms%20pedals%20-%20Rotating%20Clock%20Divider%20&hersteller=Modular%203%20HE&kategorie=kategorie&currency=EURO_BRUTTO
anybody owns it and the G2 and might check if its similar?..
however.. the good ol pattern generator seems to be a cheaper choice for similar things...
Rotate Clock 1.pch2
 Filename:  Rotate Clock 1.pch2
 Filesize:  4.06 KB
 Downloaded:  348 Time(s)
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 1:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a DIY clock divider, where the division count can be set (or modulated) by a control signal. It's a full replica of the Clavia clock divider module, meaning that the behaviour of the clock and reset inputs is 1:1.
The only caveat is divider settings lower than 1. This could be prevented with extra circuitry.
The patch can be simplified and thus economised a bit if you do not need the exact behaviour like the ClkDiv module (eg. the barred reset input).
DIYClockDivideTK.pch2
DIY replica of the ClkDiv module
 Filename:  DIYClockDivideTK.pch2
 Filesize:  1.56 KB
 Downloaded:  383 Time(s)
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Smile you are realy the master patcher on the G2 Wink
i think i need your help with another issue aswell.. but i wil start another thread for that..i would like to have a pitch transposer based on a ram table so one can reverse the readout while running.. sounds impossible on the G2.. but ..looking at your patches its probably not.. have you done such a thing allready by chance?
greets from a finaly sunny berlin,
sven
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean simply a sequencer which can run backwards?
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
no.. a diy pitch transposer with variabel readout.. or a granualr sampler if you want.. pretty much the same.... but defenetly not easy.. the better ones on the market like the old publison even looks for trasients ad trys to let them pass.. i just started to experment with the pitch transposer module but it seems to be very limited sound wise.. just theese 3 settings for the delay lenght, this should be variable and modulateable aswell
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, you mean a pitch shifter. Smile
A DIY pitch shifter with variable delay length is possible. I can do it. But what do you mean by "variable readout"?
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
looking at your revious patches i am sure that you have the necessarry technology allready.. Smile so when one can do it its probably you..
variable read out.. i would like to have a very veratile readout... the szise of the grain should be variable..not like now 3 fixed szises.
the read outrate that defines the amount of pitch shifting should be
modulatble to add some jittering vibrato...
the read out direction should have different selctable directions.. forward...backwards..
maybe alternating.. but that is maybe not necessary
in adition to that core grain cell some analoge modeling..saturated feed back aso. is needed to get it at least a bit sounding like the old style pitch shifters... but thats a point where i might chime in... actually i had the idea to try to modefy one of your patches.. but i dnt really understand how they work.. Smile
i like theese science fiction sounds that are nice and fat shimmering but not realy a shift pitched signal as we know it today..
the internal pichshifter is not too far from that direction because its a rather primitiv one.. but dont think that it works with a variable readout rate and the mixture of the lofi by design with the hi fi 96 k processing dont sounds too nice.. i hope from a diy modue that it really can create some intersting glitched sounds..
at least it would be nice to have such fx available on the nord..
at least no sample storing is issed with this kind of realtime sample manipulations..
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
What you are looking for is a delay line which is read out by a grain engine. This is not 100% the same as the classic pitch shifter design. With the pitch shifter design, the crossfading speed (which, OK, can be thought of as a sort of grain frequency) changes with the amount of shift. So, if you would want to add pitch jitter functionality, the crossfading speed would have to jitter accordingly. Same with delay line size, which will also affect the crossfading speed reciprocally.
With the granular approach, the grain frequency (=size, reciprocally) will be constant, even when pitch shifting amount is zero. So the artefacts will be present regardless of pitch shifting amount. This design would basically be my polyphonic granular synth reduced to 2 grains and minus the "pseudo-sampling". (Or you can have 4 grains after all if you want). Reverse grain playback isn't possible, as it would require a complete second bank of expo-tracking readout pointer calculations, which would go over 100% DSP very fast.
But is this what you are looking for?
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
maybe..sounds interesting.. i ve to hear it to see ..but the old style pitchshifters are defently not sounding neutral on zero shift but why isnt it possible to have forward and backward read out?..
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Technically it is possible (obviously). But on the G2 it wouldn't fit on a DSP anymore, as calculation of precise expo-tracking readouts is the hardest part of this kind of patch.
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
ok.. ..you say you have done his allready as part of a polyphonic grnular synth? do you have a simpler version of this patch one might be able to access?
Akum420
G2 patch files: 11
PostPosted: Sat Jun 05, 2010 10:17 am    Post subject: Reply with quote  Mark this post and the followings unread
You can assign a #cc to the divider parameter on the Parameter Overview page and use a MIDI control send module and set the same #cc. This module have a modulation input.
Tim Kleinert
Audio files: 6
G2 patch files: 201
PostPosted: Sat Jun 05, 2010 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. It's the exact same principle. However, it has to be modified in order to work with a "normal" delay line (as opposed to the looped "pseudo sample memory" delay).
No. Smile It has to be taken apart quite a bit because some things work quite differently when implemented this way. Actually I had the idea to do this for quite a while. I'll see if I can get a shot at it.
beer
3phase
G2 patch files: 138
PostPosted: Sat Jun 05, 2010 10:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh please..go along.. have the first shot.. i do it later than Very Happy
good luck..
Moody33
PostPosted: Tue Oct 26, 2010 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
A DIY clock divider as wrote in the manual.
Cycle :2
Memory: 16,4.
clockdividerG2.pch2
 Filename:  clockdividerG2.pch2
 Filesize:  885 Bytes
 Downloaded:  288 Time(s)
gb
PostPosted: Fri Sep 02, 2011 6:33 pm    Post subject: Rotating Clock Divider Reply with quote  Mark this post and the followings unread
I use my hardware rotatingclockdivider from "4ms pedals" constantly and love it!
here's my emulation patched on the g2-demo.
Should exactly do, what the original does...try it out.
you can use it either with a constant value or with a random/lfo/seq.line to get some polyrhythmical stuff. (switch 1/2)
cheers
gb
zurich
Rotating_Clockdivider.pch2
 Filename:  Rotating_Clockdivider.pch2
 Filesize:  2.73 KB
 Downloaded:  231 Time(s)
iPassenger
G2 patch files: 78
PostPosted: Sat Sep 03, 2011 9:37 am    Post subject: Re: Rotating Clock Divider Reply with quote  Mark this post and the followings unread
cheers
gb
zurich
Nice. Smile Like it.
iP (Ross)
gb
PostPosted: Sat Sep 03, 2011 4:26 pm    Post subject: Re: Rotating Clock Divider Reply with quote  Mark this post and the followings unread
Maybeeeee i'll have to buy a real g2...Wink
Gb
AmbiphonicDSP
