Joined: Jan 07, 2009 Posts: 1196 Location: Scottish Borders
Audio files: 155
loydb
Joined: Feb 04, 2010 Posts: 393 Location: Providence, RI
Audio files: 155
Posted: Sat Oct 16, 2010 7:19 am Post subject:
here's some sounds.....
Description: |
sweep of cutoff with no resonance applied |
Download |
Filename: |
mfos sv-vcf sweep no res.mp3 |
Filesize: |
888.98 KB |
Downloaded: |
1337 Time(s) |
Description: |
sweep of cutoff with resonance set to 3/4 |
Download |
Filename: |
mfos sv-vcf sweep with res.mp3 |
Filesize: |
799.79 KB |
Downloaded: |
1355 Time(s) |
Description: |
vcf lowpass & bandpass mixed out with sqr lfo on cv2 input , and tri vc-lfo on cv1 input |
Download |
Filename: |
mfos sv-vcf lfo mod.mp3 |
Filesize: |
2.98 MB |
Downloaded: |
1375 Time(s) |
wmonk
Joined: Sep 15, 2008 Posts: 528 Location: Enschede, the Netherlands
Audio files: 15
Audio files: 155
Posted: Sun Oct 17, 2010 3:37 am Post subject:
Looking great Thomas , good choice having the sockets at the bottom of the panel , easy access to the dials .
How do you fix your pcbs to the panel , do the pots / sockets hold an L bracket or do you bolt through the front panel like i do ???
What caps did you choose for C2 , C3 ? .
id love to hear your filter after completion
Dave |
wmonk
Audio files: 15
Audio files: 155
Posted: Sun Jan 09, 2011 4:31 pm Post subject:
Hey Woody , cool sounds on the radio jam tonight , what kind if dials are you going for , moog style or mixer or soft touch mini dials ???? |
tazer
Posted: Tue Jan 11, 2011 9:44 am Post subject:
mfos 12db filter Subject description: input volume |
Hi great modules guys!
wondering if anyone can give me a tip about mine, the output volumes are noticably quieter than my other filters. Could anyone tell me which resistor i could change and an approriate resistor value to fix it with, to boost the output volumes.
many thanks
http://www.musicfromouterspace.com/analogsynth/statevariablefilter.html[url][/url] |
Audio files: 155
Posted: Thu Jan 13, 2011 10:56 am Post subject:
Hi tazer
I noticed that as well , i think it's to do with the state var. vcf using 1 LM13700 (6dB per side) , the 24dB filter obviously uses 2 LM13700's and is louder , i simply turn my vca up a little to compensate.
Unless you build 3 pre-amps maybe , one for each out (Ray has info on op-amp gain calculations in his how to / synth 101 pages on the mfos site) or you could run it through a simple vca to boost it.
Good luck
Dave. |
tazer
Posted: Fri Jan 14, 2011 3:24 am Post subject:
Hey Dave
thanks for your speedy response, i should have known it wouldn't have been so straight forward as a resistor (maybe wishful thinking!). Thanks for the advice-have you got a link to your pics of your modular anywhere? I've only seen bits and pieces-it looks really pro. How long you been building it? I've been building mine for about a year and just finished my first cab, i'm gonna post up some pics soon. My wiring defo needs some work but that will come with time they turn into such a big project you need to be multi skilled-the modules i've seen of yours all look compact and neat though.
easy now |
wmonk
Audio files: 15
Posted: Sat Jan 15, 2011 7:24 am Post subject:
Time for some samples.
The first one is a filter sweep as Dave did, using different settings of resonance. Every setting of resonance is played twice, with one having the band pass output inverted in the mix, the other all same polarity (those are somewhat more quiet).
The second is a sequence, again the sound source is a SN Voice pulse output. Using the different ouputs of the filter, first lopass, then bandpass, then highpass.
Last one is a fun trick with the VC Resonance to accent notes. Used gates to do this. Same sequence.
Have fun listening, I can really recommend this module!
Oh, I know I'm using a 12dB/Oct filter for a bass sound, just wait till I get my Oakley Superladder done
Woody
Description: |
Filter sweep. Sound source is the SN Voice pulse out. |
Download |
Filename: |
20110115-filtersweep.mp3 |
Filesize: |
3.05 MB |
Downloaded: |
1579 Time(s) |
Description: |
Sequence with the MFOS SVF. Different output, different sound. |
Download |
Filename: |
20110115-filteredsequence.mp3 |
Filesize: |
4.63 MB |
Downloaded: |
1511 Time(s) |
Description: |
And the last one, same sequence with VC Resonance turned up, and played with gates. :-D |
Download |
Filename: |
20110115-sequence-vcresonance.mp3 |
Filesize: |
1.78 MB |
Downloaded: |
1473 Time(s) |
_________________ Weblog! |
Audio files: 155
Posted: Sat Jan 15, 2011 10:38 am Post subject:
Nice sequence
sounding good Woody. |
