 Forum index » Instruments and Equipment » Nord stage
Nord Electro 3 HELP w Live buffer
Page 1 of 1 [2 Posts]
Phant82
PostPosted: Sat Apr 02, 2011 11:16 pm    Post subject: Nord Electro 3 HELP w Live buffer Reply with quote  Mark this post and the followings unread
Hello. I almost always run my Nord Electro 3 in the Live buffer setting. I lent my Nord to a friend, and upon receiving it back, I fired up the Nord and there was no output signal coming from it when I had it in the Live buffer setting. If I switched to Prog A or Prog B, I would get an audio signal just fine. But in the Live buffer setting, I tried both L/R Output jacks, as well as the headphone jack, and got nothing. Any advice? This seems to be a very odd symptom.
Thanks,
Billy
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Apr 03, 2011 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Not owing an Electro3 (still on NE2) I only can suggest your friend shut down the sound as last action before returning it to you... Remeber, it 'holds' to last changed setting of the Panel. A and B function normal, so nothing appears to be broken...
Hope this helps.
Wout
