 Forum index » Clavia Nord Modular » G2 Patches - Completed » Lead
Harmonic distortion...popping sound when sequencing??
Page 1 of 1 [4 Posts]
svoboda
G2 patch files: 4
PostPosted: Wed May 11, 2011 9:30 pm    Post subject: Harmonic distortion...popping sound when sequencing??
Subject description: does anyone now whats this popping sound in this patch?
hi all,
this is the harmonic dist patch from roland..
ive customized it with SEQ.....
and when sequencing from cubase i get these popping sounds especially in the low end of the filter cuttoff..
is this an overload 'clipping' pop?
if i back off on the gain it seems to get less obvious..
but then i loose some of that 'dirty distortin. which this patch does well...
hopefully someone here can load the patch and check it out..
thanks!
harmonicdistortion SEQ1.pch2
SEQ distortin Mods.....
popping sound??
 Filename:  harmonicdistortion SEQ1.pch2
 Filesize:  4.08 KB
 Downloaded:  1230 Time(s)
Roland Kuit
G2 patch files: 127
PostPosted: Fri May 13, 2011 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
an extra high pass filter will do the job. I altered the pch a bit.
harmonicdistortion_seq2.pch2
 Filename:  harmonicdistortion_seq2.pch2
 Filesize:  4.25 KB
 Downloaded:  1303 Time(s)
svoboda
G2 patch files: 4
PostPosted: Fri May 13, 2011 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks Roland,
ill load it in the synth tomorrow,
just had a quick look in Demo software.,
theres a few things i still dont properly understand about the G2,
like why did you put the level converter before the FM, (i think you did)
ive noticed that ENV on FM needs to be flipped, but usually i flip it on the ENV itself.
any way
ALlWaYS LEARNING
Roland Kuit
G2 patch files: 127
PostPosted: Fri May 13, 2011 10:59 am    Post subject: Reply with quote  Mark this post and the followings unread
I used the lev conv to get a a complete negative mod signal from the seq module. the lev mult I is used to get a changing fm amount on osc c1.
