need help on choosing parts (or a link where it is already)
Page 1 of 1 [6 Posts]
cavage
PostPosted: Tue Aug 02, 2011 7:15 am    Post subject: need help on choosing parts (or a link where it is already) Reply with quote  Mark this post and the followings unread
helllo
the guy who is building me the klee almost finished and all is needed now is filling the klee panel with leds, switchs, potentiometers etc ...
the guy cant find the values for all that populate teh panel ...
is there a place here were the parts are listed with theyre values or do i have to find a doc or some other info point ?
help greatly apreciated ....
wmonk
Audio files: 15
PostPosted: Tue Aug 02, 2011 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
It all is in the building documentation. Just out of my head I think the 16 step potentiometers are 50k, the glide potentiometers 1M, and all others 100k.
I'll look up the page in the guide.
Weblog!
wmonk
Audio files: 15
PostPosted: Tue Aug 02, 2011 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Just for clarity a new post.
Page 18+ gives a list of all the panel mount components. Potentiometers are indeed 50k for the 16 programming pots, 1M for the glide pots, and others 100k. All linear.
All gate bus select switches are on-off-on type, single pole. There are 16 of em. Invert B and optional internal/external range switch are of the SPDT on-on type. Other toggle switches are of the SPDT on-off type.(you can use the same switches for those, mind the orientation though)
Manual step and Load are momentary on pushbuttons, The range switch is a 1P8T rotary switch.
Woody
Weblog!
cavage
PostPosted: Wed Aug 03, 2011 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for the fast respons
i guess my builder is a bit lazy... i am a bit afraid of the works he's gonna do on this finally...
anyway thanks, i transmit the infos !
regards
b
PostPosted: Wed Aug 10, 2011 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like to also stress that it is VERY important to get the best momentary switches you can. Especially the manual STEP switch. Crappy switches lead to much bounce or failure.
Bill
mumblinstevedubya
PostPosted: Tue Sep 17, 2013 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Greetings!
Has anyone in the UK got links to the mometary push button switches they have used.
Thanks
Steve
