ERRATUM ARP4072 BRIDECHAMBER PCB
Page 1 of 1 [2 Posts]
yusynth
PostPosted: Sun Oct 18, 2009 12:44 am    Post subject:  ERRATUM ARP4072 BRIDECHAMBER PCB Reply with quote  Mark this post and the followings unread
Hi all
Just want to let you know that I made a mistake in the silk-screen of the Bridechamber's PCB. Scott Deyo is directly using the Gerber files that I send him, therefore I am the one to blame for this mistake Embarassed
The legends for the output conector are swapped, the output pin is labelled GND and the ground pin is labelled OUT. Obviously this resulted in a silent filter and the fix consist in swapping the output connections !
I sent a fixed Gerber file to Scott Deyo , therefore I expect that the next Bridechamber's batch of this PCB will be correct.
I apologize to those who have been facing this problem with their yusynth ARP filter because they trusted the silk-screen.
Yves
roman_f
PostPosted: Thu Oct 06, 2011 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
the problem is not fixed yet - it's oct 2011 and i've spend the whole evening swatting the components and searching bad soldering on the board
finally the multimeter told me that GND is on the same bus with output :)
