 Forum index » Clavia Nord Modular » Nomad - NM1 Open Source Editor
nomad editor -> cant load onto the NM1, I got "error" on LCD
chupchups
PostPosted: Sun Oct 09, 2011 6:46 am    Post subject: nomad editor -> cant load onto the NM1, I got "error" on LCD Reply with quote  Mark this post and the followings unread
Hellooo!!
I succeeded in making working nomad on my mac 10.6.6 (see previous post). good for me Smile
Now, sometimes, I got a error message on the synth LCD display.
I explain, I load a patch in the nomad editor, then I save it into the synth -> the lcd display of my NM1 mentions "error"...
at the same time, I loose the connexion between the synth and the nomad!
I can't save the patch into the synth, strange?
I re open an old PC win xp, and it works with the clavia editor (version 3.03).
I made tests that may show that USB connexion, nor midi are an issue.
* Can you help?
- is it a patch issue?
- is it a nomad issue?
- I could look at the nomad logs? where is it located?
I can give you more details if you like (name of a patch that dos not work...).
