LFO contour on Virus
Page 1 of 1 [4 Posts]
audiodef
Audio files: 53
PostPosted: Thu Jan 12, 2012 11:54 am    Post subject: LFO contour on Virus Reply with quote  Mark this post and the followings unread
Can we get a sub-forum for the Access Virus (all models)?
Anyway, I learned something very interesting about my Virus B - the LFO contour function. This morphs the LFO from one waveform to another. A sine is morphed to either a triangle or a square. A triangle morphs to a sawtooth. Sawtooth morphs to either a square or an exponentially declining decay. A square has its PW modulated. For all other table waveforms, contour zooms in on the wave and shortens it.
If you crank up all the values on an LFO while using max contour, you can get some really wild stuff.
There's an invisible radio gnome playing a gong from a flying teapot - don't miss out!
klangumsetzer
Audio files: 32
PostPosted: Tue Jan 17, 2012 12:37 am    Post subject: Reply with quote  Mark this post and the followings unread
hej audiodef!
this sounds interesting, can you post some audio examples.
my virus kb has been in storage for quite some time now but i really miss its special sound and the high quality keyboard sometimes...
Make a joyful noise!
Eike
audiodef
Audio files: 53
PostPosted: Tue Jan 17, 2012 3:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Eike,
Yeah, some samples would help show this stuff, so here they are. These are all the same patch.
nolfo.ogg
Before edits, no LFO (base reference)
 Filename:  nolfo.ogg
 Filesize:  79.18 KB
 Downloaded:  936 Time(s)
sine_lfo_no_contour.ogg
Sine wave LFO, no contour applied
 Filename:  sine_lfo_no_contour.ogg
 Filesize:  118.92 KB
 Downloaded:  979 Time(s)
sine_lfo_pos_contour.ogg
Sine wave LFO with positive contour
 Filename:  sine_lfo_pos_contour.ogg
 Filesize:  117.69 KB
 Downloaded:  1013 Time(s)
tri_lfo_pos_contour.ogg
Triangle LFO with positive contour
 Filename:  tri_lfo_pos_contour.ogg
 Filesize:  155.63 KB
 Downloaded:  971 Time(s)
tri_lfo_neg_contour.ogg
Triangle LFO with negative contour
 Filename:  tri_lfo_neg_contour.ogg
 Filesize:  160.05 KB
 Downloaded:  1012 Time(s)
audiodef
Audio files: 53
PostPosted: Tue Jan 17, 2012 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Continued...
wave14_lfo.ogg
Wave 14 LFO, no contour
 Filename:  wave14_lfo.ogg
 Filesize:  150.36 KB
wave14_lfo_pos_contour.ogg
Wave 14 LFO, positive contour
 Filename:  wave14_lfo_pos_contour.ogg
 Filesize:  188.17 KB
 Downloaded:  982 Time(s)
wave14_lfo_neg_contour.ogg
Wave 14 LFO, negative contour
 Filename:  wave14_lfo_neg_contour.ogg
 Filesize:  175.44 KB
 Downloaded:  939 Time(s)
mixedup.ogg
LFO's 1 and 2, both with contour, applied to various parameters, with a little FM thrown in for good measure.
 Filename:  mixedup.ogg
 Filesize:  379.06 KB
 Downloaded:  907 Time(s)
