varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Thu Dec 29, 2005 2:43 am Post subject:
mono monster! Subject description: A monsterous monophonic synth! |
"mono monster VM" - A monsterous monophonic synth!
Why is it a monster? Because it is a huge, ugly, DSP Patch Cycle eating monstrosity!
This patch is based on the "MiniMoogy G2" patch posted in the Classics patch subforum. This one retains some of the minimoog features like octave pitch range switches - pink noise, red noise and Osc 3 as audio range modulation sources.
Some new features:
There are three oscillators, from each one any combination of three waveforms can be crossfaded - triangle, sawtooth, and pulse. The pulse waveform has adjustable pulse width. The edge of the sawtooth is phase synched with the peak of the triangle (just like the mini oscillators), as is the leading edge of the pulse wave. Osc 2 and Osc 3 have ultra fine keyboard tracking detuning adjustments.
There are two LFOs with wave shaping. The filter frequency can be modulated by a crossfade mix of LFO1/Osc3/Noise and LFO 2.
There are three ADSR envelope generators, one each for oscillator pitch, filter frequency, and amplitude.
The effects include EQ, phaser, delay, stereo chorus, and reverb.
This patch is designed to be tweaked from the G2 front panel. Check out all the knob/button assignments.
Description: |
Download |
Filename: |
mono monster VM.pch2 |
Filesize: |
7.75 KB |
Downloaded: |
2819 Time(s) |
_________________ varice |
varice
Audio files: 29
G2 patch files: 54
varice
Audio files: 29
G2 patch files: 54
Posted: Sat Jan 28, 2012 10:24 pm Post subject:
Another mono monster version |
I’m way past due for sharing some patches instead of just lurking, so…
Here is another version of the mono monster patch. There are many changes.
The edge and phase of the pulse waveform is not correct in the previous versions (now on OS 1.40). I thought that I had checked that carefully with my scope back when I built the first patch in 2005. Did Clavia change something about the OscShpB module since then, or did I just mess that up? Anyway, this version now has the phase of the triangle, sawtooth, and pulse/square waveforms aligned properly in each oscillator bank (like the waveforms produced by the CEM VCO IC chip used in the Prophet-5 rev3 and many other analog synths). But this phase correction required a more DSP hungry oscillator bank patch, so to keep a 3 Osc bank synth, I had give up the noise source section and the audio rate modulation of the Osc banks. By using the OscShpB module though for both the triangle and pulse waves, this allowed two new features. The triangle wave shape now can be continuously morphed from a triangle to a ramp up or ramp down sawtooth wave. The phase of pulse/square wave can now be shifted relative to the phase of triangle/sawtooth waveforms in each oscillator bank using the associated P Phase offset knob. Tip: Normally the fundamental frequency of the square wave is shifted by 90 degrees when the P Phase offset knob is set at the value of 0. By setting the value to +32, the fundamental of the square wave is in phase with the fundamental of the triangle and will result in a strong fundamental frequency when the triangle and square waves are crossfaded together. A great waveform for powerful bass and mellower lead sounds (check out Variations 1 and 8 ). Setting the value to -32 will put the square wave 180 degrees out of phase with the triangle wave, stripping much of the fundamental frequency of a triangle/square crossfade, resulting in a wave shape that cannot be produced by any of the G2 oscillator modules alone (check out Variation 2). Also note that the phase of the pulse/square wave is only updated on the rising edge of a new note gate signal and that the min/max settings of the P Phase offset (-64 and +64) do not work (the value must be greater than -64 and less than +64).
The delay and reverb sections in the FX area now have input faders/switches. The G2 delay and reverb modules have only dry/wet mixers/bypass switches on the output. This is not ideal when switching variations, where you desire the natural delay decay/reverb tail in the sound of a previous variation after switching to another variation with no delay and/or reverb selected for the new voice. Also, the reverb module is too easy to overload, so I find that an input fader set to -6dB or more to be very useful.
The delay section in the FX area of this patch uses a FltClassic filter module in the feedback loop. This module produces a nice overdrive distortion along with adjustable high frequency cutoff filtering. At a unity gain or greater feedback (FB knob) setting, the result will be an increasingly distorted regeneration sound which resembles the type of high feedback distorted sounds that analog bucket brigade type delays produce. Tweaking the Delay FB, LPF cutoff Freq, Res, and HPF cutoff Freq knobs will provide many different delay sound flavors.
The reverb section in the FX area of this patch has an alternative mode selection, Output B. Normally, either Output A (the default output of the reverb module) or Output B should be selected. The reverb module has resonant and interference (cancelation) frequency nodes, depending on the reverb Type and Time settings. Selecting Output B will give a different resonant/interference result in the Left and Right mix (stereo) outputs. Output B does not really sound better than Output A, but it just gives a different reverb sound for a particular audio frequency input.
The function of the Saturate module used to distort the Oscillator mix sound before the filter input has been changed. Unfortunately, the Saturate module produces a lot of undesirable digital aliasing noise, even at low settings. The Saturate modulation amount is now tracking the note value in a manner in which higher notes will produce less saturation (and therefore less aliasing noise).
With the removal of the noise section as a sound source for the Mixer, that former noise input is now free. This patch uses this input for a 1 sample delay positive feedback loop, the feedback amount adjusted with the Drive knob. This is an old but very nice mixer feedback trick that provides an adjustable mix boost along with a high frequency rolloff.
Description: |
Download |
Filename: |
mm 3 Osc VM.pch2 |
Filesize: |
9.16 KB |
Downloaded: |
4564 Time(s) |
varice
Audio files: 29
G2 patch files: 54
varice
Audio files: 29
G2 patch files: 54
Electromagnetic Wave
G2 patch files: 38
Posted: Sat May 11, 2013 5:03 pm Post subject:
I love to learn from this patch. Very helpful for me. Thanks to spot the issue with "the EG modules when placed in the FX area" in another topic.
I play with the last "mono monster" patch you post. Have you tried to recreate a sound from somewhere? Variation 1 and 8 are so close from a song of Infected Mushroom (Send Me an Angel).
Variation 8 at 5m15. I edit a little bit the Pitch Env and the filter and WOW.
Variation 1 at 5m30. Just edit the Amp Env and the Filter. This variation is so close than I get a big phase issue with the sound in the song when I play it on my NMG2 together.
Variation 1 is more a traditional lead sound than the Variation 8 but Im surprised to get 2 variations so close from 1 song into the same patch.
I don't want to talk about the evolution of the style of music of Infected Mushroom here. But I think it's always nice to hear the sounds they create. |
varice
Audio files: 29
G2 patch files: 54
Posted: Sun May 12, 2013 4:31 pm Post subject:
Electromagnetic Wave wrote: | I love to learn from this patch. Very helpful for me... |
I’m glad that you like this mono monster patch.
Electromagnetic Wave wrote: | ...I play with the last "mono monster" patch you post. Have you tried to recreate a sound from somewhere? Variation 1 and 8 are so close from a song of Infected Mushroom (Send Me an Angel)...
...Variation 1 is more a traditional lead sound than the Variation 8 but Im surprised to get 2 variations so close from 1 song into the same patch... |
No, I didn’t try to recreate any particular synth sounds from songs in the Variations. I only wanted to demonstrate the variety of synth sounds that this patch is capable of, and provide some starting points for further tweaking. It was a design goal from the start to have one patch that could easily be tweaked to create just about any monophonic type lead or bass synth sound. _________________ varice |
dNRML
Joined: May 11, 2009 Posts: 6 Location: Calgary, Alberta, Canada
Posted: Fri May 24, 2013 8:22 pm Post subject:
It is entirely possible that they used the patch in this thread. That release was May 8, 2012 which is just after this patch was posted here.
I know Infected Mushroom use a G2 quite a lot.. I believe it is their sound design weapon of choice. This forum is probably the biggest source of nord modular patches and discussions so it wouldn't be a big suprise if this were the case.
Im not criticizing them, I think if a sound fits and you didn't make the patch, use it anyway. No sense in making the same patch yourself! |
