2k Tempco advice
Page 1 of 1 [7 Posts]
ejr27233
PostPosted: Sun Feb 26, 2012 6:41 am    Post subject: 2k Tempco advice
Subject description: Options to replace 2k tempco
I'm about to build 2 Buchla 258ish VCO's and need 2k Tempco's.
I've got 1k ones so the options are....
a, Put 2 1k tempco's in series
b. Put a 1k tempco and a 1k 1% metal film resistor in series.
or at a push
c, Order 2k tempco's from USA (not keen to do)
Which is the best option???
Any advice greatfully recieved
Sebo
PostPosted: Sun Feb 26, 2012 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that two 1K tempcos in series will work OK. The x0xbox uses two 1K tempcos in series.
1K tempco + 1K metal film will not work for sure, as the temperature coeficient will be a lot lower than needed.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
ejr27233
PostPosted: Fri Mar 02, 2012 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your help
Regards
John
L´Andratté
PostPosted: Sat Jan 19, 2013 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funny, I have the same question-
Since those tempcos are not really cheap, wouldn´t it be possible to just lower the input resistors from 100 to 47k (same relation gain 1/50)?
I´ll try it...
rabbit
rogerlatur
PostPosted: Yesterday, at 5:26 am    Post subject: Reply with quote  Mark this post and the followings unread
I´ll try it...
I am curious if you did try?
Is there any replacement then?
L´Andratté
PostPosted: Yesterday, at 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes and no...
I did build it and it gave exponential response and mediocre scaling was there, but not optimal, maybe due to other things? I don´t know, I guess the problem with the 47k is about the input impedance, maybe there´s some tiny voltage loss?
The difficulty might be the same cv would give different notes from different osc.s! {EDIT: check next post}
Sorry I´m only autodidactic halfwit Confused
Good reading:
*** ELECTRONOTES S019:scroll down here
http://electronotes.netfirms.com/free.htm
***http://www.uni-bonn.de/~uzs159/index.html
***first article under
"Projects and Misc Files"
http://home.comcast.net/~ijfritz/misc_lnk.htm
L´Andratté
PostPosted: Yesterday, at 6:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Check especially the 2nd link halfway down, it´s there!
54k:1k at 1% tolerance! Embarassed
Niio1
