  Twyndyllyngs Live Chez Mosc
Neutron DuoFonik boards for sale.
Page 1 of 1 [3 Posts]
defex
PostPosted: Wed Feb 15, 2012 9:51 pm    Post subject: Neutron DuoFonik boards for sale. Reply with quote  Mark this post and the followings unread
This is a dual version of the Fonik SSM2044 made with permission. The board is 4.2" x 2.1" so it should (just) fit on a euro panel.
Because of the inverting inputs being avaliable and having a mix out, you can get high and bandpass like responses as well as low pass.
Freq, Freq CV, Res and Res CV are not only available for A and B filters, but also "A+B" which controls both, and there is an additional "divergence" CV which moves the filters in opposite directions.
info and "buy" button are here.
http://neutron-sound.com/duofonik.html
sorry, the tested SSM2044s are out of stock, i have more on the way.
I think there are quite a few of them unhappily languishing in parts drawers though.
on my prototype i used switches to select between individual controls or A+B on the first column of knobs and the second column become offsets. (except freq CV, which becomes divergence)
MR-808
PostPosted: Tue Mar 20, 2012 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards (fast!) - they look great, and I'm just waiting on parts to stuff in them. :)
Would you mind sharing where you got those knobs from, and the part #?
defex
PostPosted: Fri Mar 23, 2012 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
sorry for the delay!
the knobs i used were "synth pointer #3" from small bear electronics. they are available in grub screw or spline shaft versions.
because the pots are a little closer together on this layout than most MOTM, they are smaller, but not the really small 5/8ths ones. it is very comfortable to use.
here is a "real" panel with the same knobs
