Octave shift when triggering a vst
Page 1 of 1 [3 Posts]
tube12x7
PostPosted: Mon Mar 26, 2012 3:19 am    Post subject: Octave shift when triggering a vst Reply with quote  Mark this post and the followings unread
Hello,
I have a question concerning the octave shift function of the Nord Wave.
When I am using the Nord wave to trigger a vst instrument, the Wave triggers C0-C5 of the vst instrument. When I try to use the octave shift function to trigger the higher octaves of the vst instrument, it doesn't work.
I also own a Nord Lead 3 which I also use to trigger vst instruments, and when I hit c3 and the octave shift of the Lead is in the middle, it triggers the c3 of the vst instrument. If I octave shift the Lead 3 by one octave, and play a C3 on the Lead, it triggers a higher octave in the vst.
With the wave, whatever vst instrument that I load, it always triggers C0-C5.
I tried changing the settings in the Wave but I didn't find a solution. Has anyone encountered the same problem or anyone has a solution?
Thanks
Ross
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 26, 2012 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
welcome tube12x7
Try holding OctUp and OctDown buttons together > the LEDs are reversed. This makes the Keyboard set to the Shift rather than the Slot, so it will affect Midi Note Out.
(I hope this works on the Wave too)
Wout
tube12x7
PostPosted: Mon Mar 26, 2012 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello Wout,
You are a life saver! Shift+Octave up and down buttons pressed together did the trick. Thank you very very much for your help thumright thumright
