 Forum index » Instruments and Equipment » Reaktor
Development of breath-controlled wind models
Page 1 of 1 [9 Posts]
Chet
G2 patch files: 35
PostPosted: Tue Apr 03, 2012 7:02 pm    Post subject: Development of breath-controlled wind models Reply with quote  Mark this post and the followings unread
I'm revisiting a Reaktor ensemble I wrote a few years ago. It was called Silverwood, and was a collection of wind physical models, controlled by breath.
I know a bit more now than then, so I'm revisiting this and trying to improve the models. I enjoy doing this, and expect this will be a work in progress.
The first update is attached. It contains some new brass models, along with some experimental alto saxophones and clarinets.
Screen shot.
 Filesize:  164.32 KB
 Viewed:  294 Time(s)
Silverwood_II_153.zip
Reaktor ensemble for breath-controlled physical wind models.
 Filename:  Silverwood_II_153.zip
 Filesize:  3.01 MB
 Downloaded:  336 Time(s)
Chet
G2 patch files: 35
PostPosted: Thu Apr 05, 2012 6:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've added two tenor saxes.
Silverwood_II_157.zip
Breath-controlled reaktor physical modeling ensemble.
 Filename:  Silverwood_II_157.zip
 Filesize:  3.06 MB
 Downloaded:  304 Time(s)
Chet
G2 patch files: 35
PostPosted: Mon Apr 09, 2012 6:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've added two oboes, a bass clarinet, and a third tenor sax.
In the woodwind snapshot names 'RH' stands for 'register hole' which kicks in for playing higher notes. 'RH DC' stands for 'register hole + distortion + comb filter', which adds a shaper and comb filter along with the register hole.
Silverwood II 164.zip
Reaktor physical modeling ensemble for brass and woodwinds.
 Filename:  Silverwood II 164.zip
 Filesize:  3.15 MB
 Downloaded:  338 Time(s)
ejr27233
PostPosted: Tue Apr 10, 2012 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Silverwood with the Eigenharp is my favourite Reaktori ens so I'm looking forward to trying these models.
Any chance of a modelled harmonica?
Many thanks for sharing
Chet
G2 patch files: 35
PostPosted: Tue Apr 10, 2012 12:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome. I think I could EQ the saxophone model to imitate a harmonica, because they're both blown reeds. But I'd need some harmonica samples to do it. Best would be every fourth semitone. One volume level minimum, although multiple volume levels (or a crescendo or decrescendo) would be better because then crescendos could be modeled.
Chet
G2 patch files: 35
PostPosted: Sat Apr 14, 2012 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I've added a flute, an English horn, a bassoon, and a tenor sax that I've tried to model after the WIVI tenor sax.
Silverwood II 173.zip
Reaktor physical models of wind instruments.
 Filename:  Silverwood II 173.zip
 Filesize:  2.47 MB
 Downloaded:  353 Time(s)
Chet
G2 patch files: 35
PostPosted: Sun May 12, 2013 5:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I had abandoned this for about a year, but recently began working with it again. There's an additional alto sax and a soprano recorder.
Silverwood II Recorder.zip
Physically modeled wind instruments
 Filename:  Silverwood II Recorder.zip
 Filesize:  2.39 MB
 Downloaded:  297 Time(s)
Chet
G2 patch files: 35
PostPosted: Sun Sep 22, 2013 6:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a small mp3 of the recorder.
Recorder.mp3
mp3 of a soprano recorder model.
 Filename:  Recorder.mp3
 Filesize:  661.22 KB
 Downloaded:  437 Time(s)
Audio files: 216
G2 patch files: 319
PostPosted: Thu Sep 26, 2013 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds good to me!
