 Forum index » Instruments and Equipment » Waldorf
Blofeld Matrix button with some delay...
Page 1 of 1 [4 Posts]
paugui
PostPosted: Thu Apr 26, 2012 4:07 am    Post subject: Blofeld Matrix button with some delay... Reply with quote  Mark this post and the followings unread
Hi
I have a Blofeld that seems to have a small problem.
The button for accessing the the LFO and EG part of the matrix sometimes has some delay.
You can hear the button clicking, but the function only changes a while after (sometimes even when I click on it another time, which makes the light change really fast).
Since it's covered by the warranty, I was thinking of taking it for a repair, but I'm just a bit afraid the tech can mess with it (my Nord G2X came back with the Mic Input not working properly...), and since the warranty expires soon, I'm not sure it is really worth it...
I know this synth has some fame for having some problems, so I'm slightly afraid that changing some pieces on it might lead to other problems, and then I won't have warranty to protect me...
Is this an easy problem to fix, or it can lead to some future troubles?
Thanks in advance,
Best
Paulo
Akai EWI3020/3030m / Alesis Fusion / Cheetah MS6 / Clavia Nord Modular G1/G2X / Creamware Noah, Scope / EMU E6400U, P2000, XL7 / Ensoniq Fizmo / Hartmann Neuron / Ibanez AD202, DM2000 / Kawai SX-240 / Korg 05R/W, A1, DSS1, EMX1, Legacy Collection, Oasys PCI, P6, P800II, SDD3000, Trident, Triton Pro, Zero 8 / Novation SBS, AS / Pearl DRUM-X / Roland D550, MKS80, R880, SRE555, VariOS, V-Synth / Soundart Chameleon / Symetrix 606 / Teisco S110F / Waldorf Blofeld kbd, mQ / Yamaha A5000, AN1x, CS5/15, FS1r
PostPosted: Thu Apr 26, 2012 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't be so paranoid! Get it serviced ASAP before the warranty runs out! Smile
ACHTUNG!
paugui
PostPosted: Thu Apr 26, 2012 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll take it to repair before the warranty expires then Razz
If the store was nearby, I would have taken it there before, but the store is still some hours away...
But I will have to go there before it expires then.
paugui
PostPosted: Tue May 01, 2012 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone had this problem too?
Is that I don't think I will pass nearby the store anytime soon, and when I'm starting thinking about it... the trip will likely cost as much as the repair would cost later...
And to be honest, the problem is not too bad, so I'm not sure what to do...
Can it be some dust, or some bad soldering that can be easily redone by someone skilled?
Thanks in advance,
Best
Paulo
