Clock Shuffle
Page 1 of 1 [3 Posts]
iPassenger
G2 patch files: 78
PostPosted: Thu Apr 26, 2012 2:30 pm    Post subject: Clock Shuffle
Subject description: Several clock dividers with the ability to shuffle between divider outputs
An attempt to mimick this: http://www.4mspedals.com/rcd.php
Clock Shuffle.pch2
 Filename:  Clock Shuffle.pch2
 Filesize:  2.97 KB
 Downloaded:  184 Time(s)
iP (Ross)
varice
G2 patch files: 47
PostPosted: Tue May 01, 2012 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I’ve finally had some time to try this patch. Very interesting. I will need to explore this one some more.
And the demo synth sounds pretty cool too… Thanks for sharing this Ross!
varice
iPassenger
G2 patch files: 78
PostPosted: Fri May 04, 2012 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks although it is not that complicated. I was hoping actually that you might have a better way of doing the clock multiply patch.
iP (Ross)
mps board
