  bingsatellites Mostly Ambient
Audio Examples of A6 Andromeda CV Modulated by Silent Way
Page 1 of 1 [3 Posts]
Infrablue
PostPosted: Sat May 05, 2012 7:43 pm    Post subject: Audio Examples of A6 Andromeda CV Modulated by Silent Way Reply with quote  Mark this post and the followings unread
This is just one note played on the Andromeda and then modulated by Silent Way LFO and Step LFO. Sound Cloud compression makes it a little blurry and noisy but this gives a good idea. Much sharper sound direct. *Edit: just learned if you download this from SoundCloud it will be original resolution.
Quite long so good for just clicking here and there for examples.
5 Main Sections: LFO CV to filter, Step LFO CV to filter, LFO CV to pitch, Step LFO CV to pitch, LFO CV to filter with less resonance. Modulated in real time, but all parameters can be automated and/or midi controlled.
Silent Way rendered and recorded at CD quality 44.1ish. Low in the mix so not the full bit range but still gives a nice idea of the capabilities.
Rendered/recorded in Logic Pro using Motu MK3 Ultralite Hybrid with Expert Sleepers Silent Way software, modulating through CV input the Alesis A6 Andromeda. A large mirror was placed behind the Andromeda so I could patch the cables in without causing further neck and back injury. If anyone would like a more lengthy example I'll see what I can do on the weekend.
CoolColJ
PostPosted: Thu Jun 21, 2012 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you tried it on the PWM?
Curious to hear if it's much smoother
Infrablue
PostPosted: Sat Jun 23, 2012 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
@CoolColJ - It did work with PWM... I didn't conscoiusly really pay attention to the smoothness, but rather was if high speed would be useful on that parameter. It worked fine but the stuff I did didn't really strike me as very useful. I'll fire it up again and have another listen for smoothness when I'm wired up again... kinda rewiring the studio with some new gear at the time.
And I'll post a demo...
emSynth
