Monotron Duo.
Page 2 of 2 [47 Posts]
Goto page: Previous 1, 2
MirlitronOne
PostPosted: Sat Apr 28, 2012 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Since the ribbon resistance change is linear, the oscillator response must be exponential otherwise the note spacing would change along the ribbon.
Life is like an analogue sequencer. Twiddle the knobs to avoid boredom.
sneakthief
PostPosted: Mon May 21, 2012 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
MirlitronOne - the microprocessor takes the ribbon voltage and quantizes it. So you can't make any conclusions about the relation of the ribbon's output to what the microprocessor is putting out.
Notice that a pulse from VCO1 is going back into the microprocessor. I believe that this allows the microprocessor to measure the current frequency and compensate for temperature drifts and other things that affect tuning & scaling (cpu-controlled auto-tune).
chorizu - look at pin 4 of the microprocessor to figure out what V/Octave that the vco's are using.
Sneak-Thief - raw electrofunk
chorizu
PostPosted: Wed May 23, 2012 3:06 am    Post subject: Reply with quote  Mark this post and the followings unread
@sneakthief-i meassured pin 4 against ground,without activating the ribbon it's 2.96 Volt.When playing the ribbon at goes down to 1.5 Volt on high notes and above 3.16 Volt on lownotes,I'd ressume that it's some feed for the OP
sneakthief
PostPosted: Wed May 23, 2012 3:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Well that seems close to 1V/Oct, albeit if you measured it correctly than it's simply inverted.
The ribbon spans roughly 18 notes (1.5 octaves) and you're getting a voltage swing of 1.66V.
However, please measure again using the chromatic scaling mode! Then you'll know for sure what the internal voltage scaling is.
Anyhow, if you look at the schematic, the voltage from pin 4 of the microprocessor gets added to the reference voltage (VD) then goes to a current mirror (Q1 & Q2) before being sent to the 2 VCO's.
chorizu
PostPosted: Wed May 23, 2012 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,thank You,I'll take me some time to make better meassurements.I ordered some micro equipments on conrad.
chorizu
PostPosted: Sat May 26, 2012 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
@seakthief-You seem to right,but i first explain my more disinct meassurement: Pin 4 to GND toggles around 2,20 Volt and 1,7 Volt(i dont no why). then i hit a high key it goes to 1,54 stable,then i hit 1octave lower it goes to 2,54 Volt.normaly it must have been reverse?
sneakthief
PostPosted: Sat May 26, 2012 4:38 am    Post subject: Reply with quote  Mark this post and the followings unread
As I said, in this case it just means that the VCO is using inverted 1V/Oct scaling.
If you want to control it externally, then invert the CV with an inverting op-amp Smile
chorizu
PostPosted: Sat May 26, 2012 5:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,alright,Thank You!
chorizu
PostPosted: Sat May 26, 2012 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
@sneakthief- i'm a little uneperienced in electronics,is this NAND gate good for my purposes
http://www.stm32circle.com/resources/Datasheets/74LX1G04.pdf
sneakthief
PostPosted: Sun May 27, 2012 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://sound.westhost.com/dwopa.htm#invert
chorizu
PostPosted: Mon May 28, 2012 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank You,very interesting suggestion and Site, too.First, i have to make oprations on how disconnect Pin 4.
TakeshiAndTheKid
PostPosted: Fri Jun 15, 2012 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey there, looking to get one of these things soon. Sad to hear there's no easy way to do a CV Pitch.
There's only one mod I really want to do though, I'm getting one because it seems really awesome for videogamey sounds. To me, having 2 square waves seems kind of redundant so I'd like to change the second square to a pulse, maybe.
Would this be hard to do?
vonkhades
PostPosted: Sun Jun 17, 2012 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys!
Im tryin to mod my DUO so I can control it externallly... I've read the whole thread but couldnt find info on it ... i've googled a lot but still unsuccesfull to find any info or schematics. The last thing Ive tried was dinsync.info/2010/06/how-to-modify-korg-monotron.html which is for the regular monotron.. but doesnt seem to work... as you said on the last messages the CV wont be easy...
Anyway there a couple youtube users that made some advancements on this.:
http://www.youtube.com/watch?v=ae6t6bN8Pyg
http://www.youtube.com/watch?v=--UNbu23DSY
I've tryied to contact them too, but no answer yet Sad
do you have any suggestions? what pads you solder or a schemmatic/resitor values?? Im sequencing it with a baby10, with both CV and Gate set max outputs to 5v.
cheers!!
andeje0
PostPosted: Tue Jun 26, 2012 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone have any updates on figuring this out?
Audio files: 29
PostPosted: Tue Jun 26, 2012 5:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I saw someone posted this - http://www.youtube.com/watch?v=1-E7qPsI4Cw
jacobwatters.com
andeje0
PostPosted: Thu Jun 28, 2012 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Hard to tell if he's really sequencing the pitch there or just the gate and the fiddling with the pitch knobs...will give it a go in the next few days and see...
andeje0
PostPosted: Thu Jun 28, 2012 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Chorizu have you had any luck testing the inverted op-amp to pin 4 of the micro-controller to control the pitch?
TakeshiAndTheKid
PostPosted: Fri Jul 06, 2012 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Is there any way to stop that annoying popping noise you get when you disengage the ribbon controller on the Duo? It kills my ears when using headphones. It's not as noticeable with the filter up but with it down it's unbearable.
andeje0
PostPosted: Fri Jul 06, 2012 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try reading some of the links of this thread on Muffwiggler -
http://www.muffwiggler.com/forum/topic-47195.html&highlight=monotron+noise
TakeshiAndTheKid
PostPosted: Fri Jul 06, 2012 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
404
TakeshiAndTheKid
PostPosted: Fri Jul 06, 2012 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah got it now. I think this is talking more about the background hiss though, and the solution looks very awkward. I get a "tapping" noise when the ribbon controller is disengaged.
Bozzy
PostPosted: Tue Dec 18, 2012 4:30 pm    Post subject: Re: Monotron Duo Reply with quote  Mark this post and the followings unread
joe wrote:
Just a quick summary:
- Vbias is the +3.36 "middle" voltage between GND and VCC.
Sorry to resume a quite old thread. I'm just interested in this topic and found this googling around... but this info was (is) incorrect.
In the Monotron DUO the +3.36V is labeled VD and serve as Digital power source (Vcc), it's not the value of Vbias.
Vbias is the +1.35V "middle" (or virtual ground) voltage between GND and VCC used in the analog section.
Bozzy
Niio2
