  bingsatellites Mostly Ambient
Interested in Tau Pipe Phaser / Flanger boards ?
Page 26 of 26 [634 Posts]
Goto page: Previous 1, 2, 3, ..., 24, 25, 26
L-1
PostPosted: Thu Mar 17, 2011 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about to replace LM394/SSM2210 transistors pairs to BC847BS ?
http://ru.farnell.com/nxp/bc847bs/transistor-dual-npn-sc-88/dp/1081234
It's NPN transistors pair in SMD package. I found characteristics very similar. I think it is possible to mount them in regular 8-pin IC socket.[/url]
L-1
PostPosted: Thu Mar 17, 2011 3:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
BC847BS is in 100 times cheaper!
bibi
PostPosted: Tue May 24, 2011 9:46 pm    Post subject: CA3086 replacement Reply with quote  Mark this post and the followings unread
New member, sorry if this has been discussed before but I can't find anything about this topic here
I'm very interested in making one of these however CA3086 and the like are long gone. What are people using as a replacement or is there still a source here in Europe beyond the obscene prices on Ebay?
The Bad Producer
PostPosted: Tue May 31, 2011 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Musik Ding sell the 3086:
http://www.musikding.de/
They're in Germany, but I'd probably order from Smallbear:
http://www.smallbearelec.com/home.html
or Bridechamber:
http://www.bridechamber.com/Hard_2_Find_ICs.html
Who are both in the States, but cheaper...
http://soundcloud.com/thebadproducer
sonicwarrior
PostPosted: Wed Sep 21, 2011 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Has anyone tried to use That 300 as a replacement for the SSM2210 yet?
Unfortunately they are not a direct replacement but with an adapter socket (Conrad 187607) this should be possible.
I'm asking because it seems that no one wants buy my second Tau Phaser PCB with a Bridechamber front and I might assemble it myself then as I have enough That 300s from a stupid order (back then I thought I would be able to design something with them).
I'm not sure if I have a use for two Tau Phasers though. Confused
defex
PostPosted: Mon Sep 26, 2011 10:42 am    Post subject: Reply with quote  Mark this post and the followings unread
I got 100 3046 from ebay for $30. they are from a US supplier, and of the ones I used for 2 phasers (22 of them) they all worked
sonicwarrior
PostPosted: Fri Jun 29, 2012 1:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I have finally wired up my first Tau Phaser but it looks like I have an error somewhere:
- The mod LFO creates slightly audible click sounds. Or is this normal?
- The CV out doesn't seem right as it puts out a constant + 9,4V
Serenadi
PostPosted: Fri Jun 29, 2012 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
No audible clicks here.
I measured at the CV output (also pin7 of U5B) a voltage between 8,7V (ccw of pitch pot) and 0V (cw). Please note this is reversed! (Any use of such signal outside of the phaser ? Wink
Please verify the components around U5B.
This output voltage is the ccw voltage of the OSC_Level pot. Maybe your +9,4V shifts the LFO output to a clipped LFO signal which causes the clicks at the phased signal.
Bernd
sonicwarrior
PostPosted: Sun Jul 01, 2012 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, that's about the same to what I'm getting. I Don't know how I got the 9,4 V, I guess it was some addition from an external CV source.
So it seems this is normal. I think the CV out jack doesn't get much use in my system anyway. I would omit it if I had not be using the Bridechamber front panel already. As it is labeled CV thru instead of out I may re-connect it from the CV out PCB connections to the 1 V/Oct in jack to use it as a passive multiple. Idea
JuneSolstice2013
