"Son Of Storm Tide" Flanger
Page 13 of 13 [304 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13
interested?
yes
97%
 97%  [ 40 ]
no
2%
 2%  [ 1 ]
Total Votes : 41
jumunius
PostPosted: Tue Jul 17, 2012 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
tiego wrote:
it does work , from either point of D1; ( works the same from the amount pot mid point still I am looking for a point where to get the ENV signal after the release control stage but before the amount stage...
(meaning I can use the env full level externally without cranking the amount inside the SOST)
I don't think such a point exists. The Amount pot is practically where the signal enters the circuit.
Also, regarding "either side of D1", yes the signal will be mostly the same, but the diode is there for reverse voltage protection. I assume if you add an out and accidentally plug the wrong thing in there you could damage your envelope circuitry.
-Jim
tiego
PostPosted: Tue Jul 17, 2012 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right
I think I did fuck up the env circuit ( worked on test then not when I patched it)
i ll check the soldering and all tomorow
rrrhaa
jumunius
PostPosted: Tue Jul 17, 2012 5:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
tiego wrote:
Right
rrrhaa
Oh I hope not! I think it's more of a precaution than anything, especially when on a modular it's so easy to patch the wrong cable in.
But I guess there's only one way to find out.
-Jim
tiego
PostPosted: Wed Jul 18, 2012 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Took my wire away from D1 checked the soldering , seems ok.
the env follower doesnt work internally in the SOST no more.
dont even know where to start to debug , I guess that D1 Diode...
Niio1
