LM13700 Wasp filter (untested)
Page 1 of 1 [17 Posts]
ickystay
PostPosted: Tue Dec 16, 2008 11:16 pm    Post subject: LM13700 Wasp filter (untested) Reply with quote  Mark this post and the followings unread
Will an LM13700 work to replace the two CA3080's in the Wasp filter? I don't know. I seem to recall guys using them in their DS-7 clones.
Anyway, I made a layout to try. I feel funny posting this among the pro looking PCB's you all fashion, but what the heck. Maybe the electrons wont mind.
This is the Juergen Haible version. Check his site and pick up the schematic here (you'll need it):
http://jhaible.heim.at/tonline_stuff/hj_wasp.html
The PCB will need to be flipped for PNP. Resize to 600dpi or 6 X 6.84 cm or 2.362 X 2.693 inches. No resampling.
Sorry for not testing this.
 Filesize:  45.4 KB
 Viewed:  648 Time(s)
 Filesize:  38.87 KB
 Viewed:  680 Time(s)
vtl5c3
PostPosted: Wed Nov 25, 2009 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should work. I remember seeing something in electronotes about the 13x00 being a drop in replacement for the 3080, as long as you overlooked the new features (diodes at the inputs, output buffer).
PostPosted: Thu Nov 26, 2009 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
IIRC it is partly even the same IC layout, just with some add-ons (diodes, buffers).
fonitronik at
n.d
PostPosted: Sun Feb 05, 2012 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
So, did anyone test this?
isak
PostPosted: Sat Sep 01, 2012 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys.
Some one test this?
I prefer to use LM13700 instead of 3080.
Is it verifid?
Isak E.
PostPosted: Sun Sep 02, 2012 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't make this PCB, but I made two Wasp filters following the schematic and replaced the 3080's with LM13700. It works fine. Apparently it is the exact same IC on the inside, but a few extra features in the LM13700.
JacobWatters.com
isak
PostPosted: Sun Sep 02, 2012 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for your reply.
Can you please share the layout you used?
Isak E.
PostPosted: Sun Sep 02, 2012 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
I just used perfboard and made it up as I went. The schematic was easy to follow and everything worked on the first try (which doesn't happen half the time I solder something).
JacobWatters.com
isak
PostPosted: Sun Sep 02, 2012 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you:)
donpachi
PostPosted: Sun Feb 08, 2015 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Only a few years late, I can confirm that the layout works Embarassed
The board was etched and populated about five years ago. This weekend I went into a troubleshooting spree and finally discovered that I had installed a wrong regulator. After fixing this and a bad trace to the resonance pot (courtesy to my etching skills) the filter rocks! Thanks for the layout ickystay Cool
n.d
PostPosted: Sun Feb 08, 2015 10:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great news!
I also need to get into a troubleshooting spree, but now, I know it´ll pay off.
***edit: this has to be the slowest thread ever, btw.***
EL BO
PostPosted: Wed Feb 24, 2016 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
why does this even need a regulator?
I mean, both those chips should be fine to +12 or +15, and surely if its a case of output levels, then its just a question of choosing a voltage divider appropriately?
while I'm at it:
I'm planning on building one up as an independent box, and plan to use 2x18650 3.7v lithium cells for power (I have ready access to heaps of these due to electric-bike stuff I do).
Really, is there any reason why I can't skip the voltage dividers (2x33k) for the non-inverting inputs of the LM13700s/CA3080s and wire in the mid point of my 2 cells instead (ie use the 'two cell option' instead of the 'voltage divider' option.) These batteries are rated for multi-amp draws, so should be not at all bothered by the draw of this circuit.
I'm not particularly fussed if this is a 'purist' WASP filter, I just want it to be near-enough..
Lance
Audio files: 20
PostPosted: Thu Feb 25, 2016 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
A pity this filter does not self-oscillate.
Is it at all possible to have a filter made with a 3080 or 13700 to self-oscillate?
donpachi
PostPosted: Thu Feb 25, 2016 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I think there are many SVF designs which do, for instance the Oakley SVF http://oakleysound.com/svf.htm or the MFOS State Variable VCF http://musicfromouterspace.com/forums.html?MAINTAB=SYNTHDIY&VPW=1900&VPH=720 .
Audio files: 20
PostPosted: Thu Feb 25, 2016 4:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, thanx!
wackelpeter
Audio files: 10
PostPosted: Fri Feb 26, 2016 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The Roland VCF's using OTA's do it too...
Build one of These System 100 VCF's and replaced that BA... OTA's with LM13700...
Have posted a stripboard layout for this one somewhere in this Forum...
Audio files: 20
PostPosted: Fri Feb 26, 2016 3:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I wasn't looking to build them, just out of curiosity Cool
But thanks anyway!
