Posted: Sun Sep 30, 2012 1:28 pm Post subject:
3x8 Step Gate/Trigger Sequencer Subject description: 4017 based sequencer, gate to trigger converter, 555 clock generator and electronic switch
Hello !!
I'm building a step sequencer and want to share with those who are interested.
With the help of schematics found on the internet, I breadboarded a nice
working sequencer.
With a 555 clock generator, the cgs24 gate to trigger converter and the 4017 baby10 based sequencer.
I build a 3x8 step gate/trigger sequencer with electronic switch.
The pcb foil I made with the help of Sprint-Layout.
Didn't do the schematics, but I can show the pcb and front design.
Also I finished the aluminium front and working on the pcb.
Next update I hope it's finished !!
Chris.
Filesize:
483.51 KB
Viewed:
507 Time(s)
Filesize:
290.29 KB
Viewed:
744 Time(s)
Filesize:
461.28 KB
Viewed:
339 Time(s)
Filesize:
432.69 KB
Viewed:
429 Time(s)
Filesize:
456.25 KB
Viewed:
591 Time(s)
The sequencer can be used as an:
3 x 8 steps (A-B-C)
1 x 16 and 1 x 8 steps (A+B and C)
1 x 24 steps (A+B+C)
The electronic switch does the work, sequencer is "yes" just the 4017.
Grt.
Chris
Filesize:
236.94 KB
Viewed:
305 Time(s)
Here is the schematic of the switch.
The pcb i posted works fine !!
CV or gate output from sequencer goes in switch A, B and C
Puls out from sequencer goes in pulse input from switch.
Eveytime the switch get a pulse, it steps to the next input.
Grt,
Chris
Filesize:
98.12 KB
Viewed:
334 Time(s)
Audio files: 6
Posted: Mon Oct 01, 2012 5:16 pm Post subject:
this is just a great gift to the community!! and it also already includes reset and manual step!!!! i believe shouldnt be so difficult to add, eventually an optional(?) cv controll and voila! waiting for updates and really curious to etch a couple of these babies
Posted: Tue Oct 02, 2012 9:38 am Post subject:
Looks to me like you could use the individual pulse outputs to drive a bank of CV pots, similar to Baby 10. It's not clear to me whether those are selectable for a specific bank (A/B/C) or would be the gate of an OR of the three banks, but either way that seems like it could be used that way.
Posted: Tue Oct 02, 2012 1:20 pm Post subject:
I'm still not sure I see how that switch can work.
Is there some way that the pulse from the sequencer is only triggering after an entire bank is complete? i.e. we step through the 8 steps of Bank A and then pulse, 8 steps of Bank B and then Pulse, and then (if not reset thanks to the spdt switch) 8 steps of Bank C and then Pulse?
I would have expected the pulse to be happening on each step.....
And if you stack all the pulse outputs of the sequencer into the trigger in from the electronic switch, it switches 8 times in a bank.
Joined: Nov 28, 2012 Posts: 12 Location: Rhode Island, USA
Posted: Wed Nov 28, 2012 10:37 pm Post subject:
That book.
Nice work, KRS - looks good.
I'm building a similar project now - 3x8, chainable, clock dividers, etc. My chaining switch is based on the exact circuit you posted.
That book is called Sound Synthesis, from 1990.
It is the source of the original "Baby 10" sequencer schematic, as well. Great book, full of useful ideas, schematics, and layouts... also chock full of so many horrible, horrible schematic mistakes, you'll be punching yourself in the face a lot if you build from it. Still - quite useful. I got it for $2 on the internet.
Best,
DM
Filesize:
103.42 KB
Viewed:
273 Time(s)
Posted: Wed Nov 28, 2012 10:45 pm Post subject:
end pulse
P.S. Elmegil --
In answer to your question, the 'pulse' coming into the switch 4017 is just the 'end out' of the sequencer... which can be tapped from pin 15 (reset) of the sequencer 4017. The 4017 in the switch circuit is a different IC than the 4017 driving the 8 sequencer steps.
So - every time the sequencer resets back to the first step, it pulses the switch to the next channel.
Posted: Sun Dec 16, 2012 9:11 am Post subject:
Re: That book.
Best,
DM
thank you very much for the info, i'm saving this for future buy!
