 Forum index » DIY Hardware and Software » Musical Interfaces
M audio finger trigger
Page 1 of 1 [5 Posts]
wheely
PostPosted: Tue Oct 16, 2012 4:09 am    Post subject: M audio finger trigger Reply with quote  Mark this post and the followings unread
Hi, does anyone know if i can replace the slider and nobs of my finger trigger with better ones?
If yes, what kind and where can i get them in the UK?
thanks in advance.
telbonic
PostPosted: Mon Oct 29, 2012 2:36 am    Post subject: Re: M audio finger trigger Reply with quote  Mark this post and the followings unread
thanks in advance.
What's wrong with the ones you have - are they faulty? Do they stick? What kind of knobs and sliders are in there already? How are they mounted? On the circuit board or on the front panel?
Of course even then I've made an assumption - do you mean the potentiometers themselves or the plastic bits that fit onto them?
Give us some more info! Very Happy
wheely
PostPosted: Mon Oct 29, 2012 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok ok clever clogs, you got me..
the sliders and nobs as in the potentiometers, and not the plastic bits or id have said plastic bits. We all know u can to take the plastic bits off and replace them, we all did that as kids remember. Smile
notice im asking a question about the finger trigger, if i knew loads about electronics id know all about the type of components in it, and where to find the relevant information......
but i don't, so im asking.
some of the nobs (pots) are faulty, and sliders, are just shit quality, and i use this alot for gigging.
thanks
telbonic
PostPosted: Tue Oct 30, 2012 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't got a clue what's in the trigger finger, but as you've got one, you could always open it up and take a look.
The pots and sliders should have some values printed on them which will give you a clue - googling "potentiometer values" gives a nice spot to start reading:
http://sound.westhost.com/pots.htm
Once you have thier values it's a lot easier to start finding replacements. The shape/size, mounting, shaft size, taper and so on are all things you may have to check on to find the right parts.
Take your time - it's a nice first project if you're totally new to electronics.
wheely
PostPosted: Tue Oct 30, 2012 12:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks man, ill check that out.
finger trigger is just a midi drum pad unit from maudio with some cheap pots and sliders.
thanks for the info.
