2012 Build Pictures
Page 14 of 16 [384 Posts]
Goto page: Previous 1, 2, 3, ..., 12, 13, 14, 15, 16 Next
syntherjack
PostPosted: Wed Oct 31, 2012 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Hallo,
this is my first synth - Stylophone clone (100% analog), enclosure contain parts from '70 laboratory equipment. Second synth - MFOS Sound Lab (uses one-side board), from 2011/2012.
Custom designed PCB, obsolete components.
 Filesize:  1.01 MB
 Viewed:  181 Time(s)
Cheap plastic and aluminium.
 Filesize:  632.17 KB
 Viewed:  253 Time(s)
Soundlab in compact case.
 Filesize:  842.11 KB
 Viewed:  249 Time(s)
Uses custom designed one-side, home-etched PCB.
 Filesize:  245.54 KB
 Viewed:  201 Time(s)
loydb
PostPosted: Wed Oct 31, 2012 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Love that Soundlab, nice work.
sneakthief
PostPosted: Wed Oct 31, 2012 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
yeah, nice layout - and those knobs are great!
Sneak-Thief - raw electrofunk
ashleym
PostPosted: Wed Oct 31, 2012 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Great build. Very slick graphics. I love the central button. even your wiring is neat Exclamation
Audio files: 550
PostPosted: Wed Oct 31, 2012 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
2 beautiful builds,. well done thumleft
SoundCloud BandCamp AcidTrasH Stickney Synthyards
vinnui
PostPosted: Thu Nov 01, 2012 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
My new module: Midi2CV MCV-628 (plus glide, CV buffers), mixer, and a preamp.
More pictures here.
 Filesize:  193.33 KB
 Viewed:  165 Time(s)
 Filesize:  208.9 KB
 Viewed:  168 Time(s)
 Filesize:  249.27 KB
 Viewed:  314 Time(s)
syntherjack
PostPosted: Thu Nov 01, 2012 9:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
I had to design new panel because I couldn't get bigger enclosure. When I printed it, I realized, there is no "trigger" button and it doesn't fit in "envelope section". Then I saw Dave Smith Instruments Mopho with "push it" button - so i decided to put "trigger" in the center and expose it somehow.
The knobs are really nice and small, and fit great in such tight panel. And are only 30 cents.
Jack
KRS1972
PostPosted: Fri Nov 02, 2012 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello !!
Here are pictures of my finished modules and Sequencer box.
Grt,
Chris.
 Filesize:  1.18 MB
 Viewed:  197 Time(s)
 Filesize:  1.25 MB
 Viewed:  289 Time(s)
 Filesize:  1.17 MB
 Viewed:  172 Time(s)
 Filesize:  990.51 KB
 Viewed:  182 Time(s)
PostPosted: Tue Nov 06, 2012 8:31 pm    Post subject: A side trip in the Time Machine Reply with quote  Mark this post and the followings unread
MANY thanks to Synthcube for the kit that made this possible. Once I started I couldn't stop. Easy peasy, built it in 2 days, basically. It might help that I was familiar with the circuit from troubleshooting another one, but there you go Smile
The audio is a triangle in, regen set to max negative and modulation by the LFO on its slowest setting, for the first minute or so, an then noodling with knobs after that.
 Filesize:  533.6 KB
 Viewed:  175 Time(s)
 Filesize:  528.31 KB
 Viewed:  167 Time(s)
tm2050-1.mp3
 Filename:  tm2050-1.mp3
 Filesize:  4.65 MB
 Downloaded:  510 Time(s)
PostPosted: Mon Nov 12, 2012 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
so i eventually finished the mutant vactrol filter of our much-loved mr scott stites (using a PCB i bought over at muff's):
fonitronik at
Audio files: 550
PostPosted: Mon Nov 12, 2012 4:11 pm    Post subject: The Bandersnatch Reply with quote  Mark this post and the followings unread
this weekend I finished "The Bandersnatch", a frumious lunetta soundmachine.
more info, schematics and demo's will be added here
The Bandersnatch
 Filesize:  135.18 KB
 Viewed:  564 Time(s)
PostPosted: Tue Nov 13, 2012 3:17 am    Post subject: Reply with quote  Mark this post and the followings unread
cute minisynth!
your stuff ´looks so awesome. it has character!
fonitronik at
dougseidel
PostPosted: Tue Nov 13, 2012 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
that is totally cool! great color also, and everything.
http://dougseidel/tumblr.com
dave_3283
PostPosted: Tue Nov 20, 2012 5:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
In a month, I went from completing my first module to this:
I've now got 4 Schmitz/CGS VCAs, 2 MFOS ADSRs, a MFOS State Variable Filter, and a MFOS Low Pass. Next up, a quadruple CGS LFO and 2 CGS VCOs...
PostPosted: Wed Nov 21, 2012 9:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Utility Distribution Module
Trigger/Gate mults and CV mults (including offset) built from MFOS CV/Gate distributor schematics (though I omitted the offset from one CV buffer), and Sum/Difference circuit found somewhere else. Built the three sections on separate boards and then had merry hell trying to figure out how to mount them on such a dense panel. Ended up building a stooge panel (?) from the flashing from Home Depot that others have talked about.
Not tested yet, but I'm pretty happy with the layout and wiring....
 Filesize:  213.75 KB
 Viewed:  393 Time(s)
 Filesize:  295.67 KB
 Viewed:  381 Time(s)
dougseidel
PostPosted: Thu Nov 22, 2012 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
One of those lo-fi radio shack "voice recorder" modules ($10), set up as a looper. the rca jack goes to a foot switch for recording. the knob controls the supply voltage, which slows things down.
 Filesize:  393.15 KB
 Viewed:  428 Time(s)
EdisonRex
Audio files: 171
PostPosted: Thu Nov 22, 2012 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
And a lovely case too. Do you have VCOs already to run through it?
Garret: It's so retro.
dave_3283
PostPosted: Thu Nov 22, 2012 4:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I've got a pair of Plan Bs just out of frame that I'm about to sell off. They will be replaced by a pair of CGS oscillators as well as a quadruple Utility LFO in the next week or two.
Audio files: 550
PostPosted: Mon Nov 26, 2012 9:38 am    Post subject: Enneatronic Spectralizer
Subject description: Dronebox with 9 squarewave oscillators
This is a circuit that I probably build 5 or 6 years ago, but I still had to put it in an enclosure. I originally planned
to make it into a cube shape (maybe use a photocube), but then I remembered this box I got not too long ago.
I expected it to be to small, but it was perfect! Razz
The circuit itself contains 9 (tunable) squarewave oscillators for the sound, and 9 (non tunable) squarewave oscillators
that together with some resistors, caps and transistors create a fading effect (both for LED's and sound).
It has a build in speaker + amp with volume control, but you can also plug in some headphones. I wired the output of the
amp to the tip and ring of the jack (sleeve not connected). So you can plug in a stereo pair.
The line out is actually a stereo jack that functions as a EFX S/R for the build in amp. So you can add effects while
listening through speaker or headphones Smile
I posted a recording last week which you can find here
and here's a video Cool
 Filesize:  72.08 KB
 Viewed:  368 Time(s)
 Filesize:  65.42 KB
 Viewed:  434 Time(s)
 Filesize:  82.82 KB
 Viewed:  457 Time(s)
 Filesize:  44.61 KB
 Viewed:  436 Time(s)
richardc64
Audio files: 26
PostPosted: Mon Nov 26, 2012 12:30 pm    Post subject: Re: Enneatronic Spectralizer
Nice work. Found a pic of someone viewing that display Wink
 Filesize:  77.52 KB
 Viewed:  17077 Time(s)
"I’m a New Yorker, and I know a con when I see one.” -- Michael Bloomberg
Audio files: 550
PostPosted: Mon Nov 26, 2012 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
excellent! Laughing
dougseidel
PostPosted: Mon Nov 26, 2012 1:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
that is totally fantastic!
PostPosted: Mon Nov 26, 2012 9:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's brilliant, literally Smile
What are the 4 switches for?
PostPosted: Tue Nov 27, 2012 3:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, PHOBoS. Yet again another beautiful and unique build. Quite the enclosure!
James.
Audio files: 550
PostPosted: Tue Nov 27, 2012 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
The oscillators are divided in 3 groups (of 3) and with the first 3 switches from the left I can turn the audio of
each group on/off, which makes tuning a bit easier. The switch next to those 3 is to turn the display on/off,
and the switch above the LED is the power switch.
