DIY gestural midi-instrument
Page 1 of 1 [9 Posts]
sneakthief
PostPosted: Mon Nov 12, 2012 2:06 pm    Post subject: DIY gestural midi-instrument Reply with quote  Mark this post and the followings unread
After gigging for 15 years, I got tired of having what I'm doing on stage being so opaque - and I needed a better way to actually create and manipulate sounds.
So I decided to create a new instrument to control my synths. It will also be connected to a small laser projector that will project different image fragments on me that correspond to each note - this will help create a visual metaphor similar to when you watch a musician play a traditional instrument, but without retarded and exaggerated pantomime!
Here's what it does:
Frankly, it's freaky as hell to be at this point where I can take the software in any direction... I'm dying to implement an interactive counterpoint that plays a bassline that follows the lead (or vice-versa) - like playing two instruments with one hand!
Sneak-Thief - raw electrofunk
bubzy
Audio files: 47
PostPosted: Tue Nov 13, 2012 12:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
awesome
_Richard_ Smile
JAMESveeder
PostPosted: Thu Nov 15, 2012 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This, sir, is outstanding!
Lovin' the creativity and the usability!
isak
Audio files: 9
PostPosted: Thu Nov 15, 2012 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Very cool.
Great job!
sneakthief
PostPosted: Fri Nov 16, 2012 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
So here's a first test of my visuals setup.
I whipped up something quick in Java using Processing.org. A pico-laser projector is mounted a couple of feet in front of me.
This first set of image fragments is subtle... still experimenting with images and learning how to play this crazy instrument:
transponderfish
PostPosted: Sun Nov 18, 2012 6:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed a great piece of work, very inspiring!
Please give us some details: What kind of interface are you using here (I mean the little black box with the LCD-display)?
I am especially interested in the kind of contacts inside the glove, the kind of playing you do with thumb and two touch-areas per finger is a wonderful idea, I definitely would like to try building something like it myself.
I did a Processing programme myself using a Joypad for generating MIDI-notes a while ago, which worked nicely, and as Joypads are so dirt-cheap, I think I could easily adapt it to do the thumb/finger trick, but thinking about how I could build switches/contacts into a glove leaves lots of questions concerning the mechanical work.
A few photos and some info on this part would be highly appreciated Very Happy
sneakthief
PostPosted: Sun Nov 18, 2012 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Transponderfish, everything is in the youtube video description:
Hardware:
- PIC18f4620
- 8 switches using "conductive silk"
- 2 "shift switches" for turning on sensor output (eg. flex sensor triggering midi, as demonstrated with the high notes in this video)
- adxl335 / IDG500 accelerometer/gyro combo
- spectra symbol flex sensor resistor
Software:
- MIDIbox (ucapps.de)
- heavily modified "AC Sensorizer" code
http://www.midibox.org/dokuwiki/doku.php?id=acsensorizer_04
Audio:
- Nord Micromodular
- MB-808 (TR-808 clone)
The melodic scale is set to Dorian (Root=D).
Which photos do you want me to post?
I'll post the code to for anyone who wants it.
The glove has 19 wires between it and the MIDIbox controller:
x,y,z
pitch,roll
flex sensor
10 buttons
+5v
ground
led out
sneakthief
PostPosted: Tue Dec 11, 2012 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Testing switchable note "spreads", accelerometer-controlled filters and gestures which "throw" octaves up and down:
I'm going to debut this whole setup in Berlin this Saturday (15.12.2012 - http://www.residentadvisor.net/event.aspx?429594 ) and will be touring in these cities starting in December...
15.12 berlin
19.12 ljubljana
22.12 belgrade
28.12 niš
29.12 sarajevo
4.1 zagreb
8.2 moscow
sneakthief
PostPosted: Mon Dec 17, 2012 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, finally got to test this out for real.
I was way outside of my comfort zone and completely overwhelmed by all the new things I had to keep track of and the musical decisions I needed to make.
As such, I need to concentrate more on MEANINGFUL melodic improvisation as well as proper musical passages that I can easily recall... you know, like a traditional instrument Wink
Technically everything went OK. Looking forward to implementing my body-tracking system so the images stay on me as I move and I'll be able to loosen up more.
Niio2
