  Muied Lumens Frequencies
 Forum index » DIY Hardware and Software » Musical Interfaces
Controller, Ribbon, Softpot, another.
Page 2 of 2 [32 Posts]
Goto page: Previous 1, 2
frijitz
Audio files: 54
PostPosted: Sun Nov 18, 2012 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Benjamin AM wrote:
I finally got around to getting this circuit on a breadboard. I eventually ended up using a softpot instead of using ESD ribbon. I noticed that the CV output ranged from 0V to 4V. To change this I adjusted the value of the 120k resistor attached to A4's negative input. Doubling the value(changing it to 240k) dropped the output to a range of -2V to 2V as the schematics indicates. I was curious if this sounds right.
Sounds OK. You can use whatever output range and offset suits your needs, of course. +/-2V is convenient with my system.
Also, I was curious if other ribbon controllers designs that use the softpot exhibit the phenomenon that has been deemed as the "squish factor", that is, pitch bending on finger pull off.
On the Appendage controller, an earlier voltage is put out. Scott said this eliminated the squish factor. I'm working on a new design that uses two smoothing times. This also appears to work well.
Anyhow, thank you so much for contributing this design, I look forward to the spending many hours playing this thing.
You are welcome! It's good to see someone working with it.
Edit: I forgot to mention that I used CA3080s in place of the LM13700. Seems to be no problem.
Yeah, they're the same basic circuit.
Ian
Benjamin AM
PostPosted: Sun Nov 18, 2012 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting! I can't wait to see it. Out of curiosity, does this mean that when the player removes his finger from ribbon the the CV lag time(A2-A3) will increase?
-Benjamin
OE
PostPosted: Thu Feb 27, 2014 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello! First post on this fine forum, but I was seeking a simple ribbon controller. The appendage is just too much for me at the moment - although it is an incredible design. I wanted to see if you had come up with the updated schematic you had referenced. I'd like to make a PCB for it and have it shared on the OSH park PCB fab site for free if any one wants to get a PCB for themselves (if that is OK with you, frijitz!)
Thanks for the contribution, I look forward to seeing the updated project.
OE
PostPosted: Sat Mar 01, 2014 5:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is a PCB and the corresponding schematic. It hasn't been tested yet, but if anyone wants to give it a try, they are more than welcome. I'll be getting it fab'd when I get a chance/money. I assume the diodes that are zener's can be a 1N400x type? Dimensions are ~3" x 1.4". The TL072 is a OPA134, I just didn't have the right component in the library. It will be edited when the board is finalized.
EDIT: removed.
frijitz
Audio files: 54
PostPosted: Sat Mar 01, 2014 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is an older schematic and is no longer recommended. Plus, you did not get my permission to do this.
Ian
OE
PostPosted: Sun Mar 02, 2014 12:06 am    Post subject: Reply with quote  Mark this post and the followings unread
I apologize! It has been removed. I assumed schematics posted for use were also allowed to have PCBs made. I am sorry.
softfin
PostPosted: Sat Apr 04, 2015 3:08 am    Post subject:   Reply with quote  Mark this post and the followings unread
I have a few spare softpots, so I though I could built this one on stripboard. However, all the softpots I have are 10k. Is it possible to build this ribbon controller with a 10k softpot? Advice would be much appreciated.
