Posted: Sun Oct 28, 2012 6:22 am Post subject:
my observations so far (no conclusions):
it is true, while all other outputs are 10Vpp, the sine is way weaker on my build - just 6.4Vpp when trimmed round nicely!
when i built the VCO i had no TL074 on hand, so i used TL084 instead. nevertheless, in regards to output voltage swing these parts are speced to be the same!?
today i replaced both TL084 with LM324, and now i get a nice 10Vpp sine.
i wished i could try a TL074, alas, i have only tons of TL072 in my drawer... _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
diablojoy
Joined: Sep 07, 2008 Posts: 729 Location: melbourne australia
Posted: Sun Oct 28, 2012 2:09 pm Post subject:
Interesting result matthias.
thanks _________________ In an infinite universe one might very well
ask where the hell am I
as good an answer as any |
ungleichklang
Joined: Dec 03, 2011 Posts: 62 Location: East-Belgium
Thomas_Henry
Joined: Jul 24, 2009 Posts: 108 Location: N. Mankato, MN
Posted: Sun Oct 28, 2012 3:22 pm Post subject:
Hello Fonik,
Just a quick comment: the sine is buffered by one of the Darlington pairs in the LM13700. Thus, if the triangle wave is a legit 10Vpp, then changing op-amps elsewhere shouldn't influence the sine. A more likely place to look is at the resistors surrounding the OTA.
By the way, changing the sine trimmers will change the output amplitude. Remember, the "best looking" sine is not necessarily the "best-sounding" (i.e., lowest distortion) and may lower the amplitude due to too much curve-bending. Use your ears only if you haven't already done so, and only afterwards look at the scope.
Scott and I spent a lot of time going back and forth on setting the resistor values to give 10Vpp with lowest distortion. But I suppose LM13700 variation could change this. I don't have the circuit on my breadboard anymore, but maybe Scott does for confirmation.
And, hey, how about that sync!
Thomas Henry |
Posted: Sun Oct 28, 2012 4:05 pm Post subject:
| Thomas_Henry wrote: | | And, hey, how about that sync! |
i thought even my short demo reflects my excitement. i personally favor the timbres of the triangle and saw outputs when synced. holy moly! _________________
fonitronik at
diablojoy
Posted: Sun Oct 28, 2012 4:33 pm Post subject:
| Quote: | | i personally favor the timbres of the triangle and saw outputs when synced. holy moly! |
wholly agree the sync really is wonderful.
makes me wish i could afford 6 or even 12
but my backlog is ridiculous enough as it is
perhaps if you have any LF4xx series in stock ?
I tend to use them inplace of TL0xx now.
better specs and almost unkillable
I had 3 survive reverse polarity totally unscathed the other week on a prototype board which is now working fine after fixing the offending tracks
never had a TL0xx series chip manage that trick and actually that is how i realised my error , as the top of a tl072 that is embedded in my ceiling is still pointing it out to me.
lesson learnt : dont trust the standard eagle parts library and always do your own - the LF442 has its power pins reversed in the eagle library
curtesy perhaps of someone with a slightly twisted sense of humour ? _________________ In an infinite universe one might very well
Sonic
Posted: Sun Oct 28, 2012 5:16 pm Post subject:
| Only just discovered this, and oh lordy! This sounds GREAT! I have all the parts already. Count me in for 2 PCBs, though I'm so excited I want to say more! |
Posted: Sun Oct 28, 2012 6:06 pm Post subject:
| Quote: | | as the top of a tl072 that is embedded in my ceiling is still pointing it out to me. |
I think I published the picture of the top of a TL07[1 or 2] that went popcorn on me. Entirely my own fault though. |
ungleichklang
Posted: Mon Oct 29, 2012 12:00 am Post subject:
| fonik wrote: | | Thomas_Henry wrote: | | And, hey, how about that sync! |
i thought even my short demo reflects my excitement. i personally favor the timbres of the triangle and saw outputs when synced. holy moly! |
For I'm new to the modular world, >>> could someone explain me the wireing of the sync you did in the vid fonik??
I have in my mind the the sync is for a second VCO .... do you make a loop somewhere with the PWM?? _________________ greetings from belgium, Sascha
My new blogspot: http://ungleichklang.blogspot.com
My Youtube-Channel: http://www.youtube.com/user/ungleichklang
My old google-site: https://sites.google.com/site/ungleichklang/home/s-diy
Linux Musician |
Posted: Mon Oct 29, 2012 2:56 pm Post subject:
in this special case i
1st: feed the 1V/oct input of the 555-VCO with a cv sequence. then
2nd: i apply a square wave from another VCO (fixed freq and PW) to the sync input (gives this robotic synced sound). then
3rd: i apply a small amount of a triangle from a LFO to the exponential FM input (gives you these phasing overtones). _________________
fonitronik at
Silesius
Posted: Mon Nov 19, 2012 3:09 am Post subject:
Hi, I'm thinking on building a couple of this vco's. I've been waiting for the pcb's, but I'm not sure if this is going to happen, so I think I'm going to try a stripboard version. The circuit is simple enough, and I think I am able to do it, if I am careful.
But I've never tried to match transistors, and I think it's a little too much for me. It would be nice to just buy some matched pairs. I've been looking a little on ebay and some online shops, but I can't find matched 2n3906's. So my question is: is there any easy substitution for that? Would any general purpose matched pnp's work here (let's say a bc557)? Or something like the ssm2220?
Any suggestions would be very appreciated. Thanks! |
Posted: Mon Nov 19, 2012 10:38 am Post subject:
it will happen, the new prototype PCBs are ordered allready and should arrive early in december.
re transistors. i did not match mine, i just used two from the same batch. as you can hear in the demo vid this is sufficient, i don't can show you any measuremtns, though. _________________
fonitronik at
Silesius
Posted: Mon Nov 19, 2012 11:49 am Post subject:
| Thanks, fonik. I think I'll wait for the pcb's in that case. You can count me in for two of them. By the way, is there any chance to get the TH controller LFO pcb's as well? Maybe at the same time? That would be great. |
Sonic
Posted: Mon Nov 19, 2012 6:09 pm Post subject:
| Quote: | | the new prototype PCBs are ordered allready and should arrive early in december. |
ungleichklang
Posted: Tue Nov 20, 2012 11:21 am Post subject:
| fonik wrote: | it will happen, the new prototype PCBs are ordered allready and should arrive early in december.
Coool, happy happy
| fonik wrote: |
re transistors. i did not match mine, i just used two from the same batch. as you can hear in the demo vid this is sufficient, i don't can show you any measuremtns, though. |
aarrg, I got a bunch of matched 2N3904 -- will order new stuff mid december, so the 2N3906 should be in this year ready for matching  _________________ greetings from belgium, Sascha
Linux Musician |
JingleJoe
Joined: Nov 10, 2011 Posts: 789 Location: Lancashire, England
Posted: Fri Nov 30, 2012 3:33 am Post subject:
| ungleichklang wrote: | | fonik wrote: |
i wished i could try a TL074, alas, i have only tons of TL072 in my drawer... |
I have some lying here ... do you need them now?? could make a letter monday mornin .. |
I was going to suggest that too but then I saw the timestamp
I don't know if I ever mentioned but this VCO is really appealing to me be- oh wait, I already said it in the first post  _________________ As a mad scientist I am ruled by the dictum of science: "I can't really be certain but I think I might have an idea"
Green Dungeon Alchemist Laboratories |
oculus
Joined: Oct 30, 2011 Posts: 18 Location: Iceland, Reykjavik
Posted: Sun Dec 09, 2012 7:56 am Post subject:
hi there matthias. are you using 12volts or 15V?
has anybody made this using 12volts?
Thanks. Fridfinnur |
oculus
Posted: Sun Dec 09, 2012 3:27 pm Post subject:
| fonik wrote: | | you can run it on 12V without any changes. |
nice thank you, i guess there´s no way out, i have to make one. btw thanks for posting the video it sounds really nice |
Posted: Sat Jan 05, 2013 2:45 pm Post subject:
re sine output.
powering the module from +/-12V, i had to lower R27 to 33k in order to get the 10vpp amplitude on the sine wave.
my recommendation for any build, even 15V systems:
lower R27 to 33k, raise R24 trimmer from 25k to 50k (or even 100k multiturn). then you should be fine. _________________
fonitronik at
stubbyfex
Joined: Sep 08, 2009 Posts: 1 Location: Denver, Colorado
Posted: Sat Jan 19, 2013 1:40 pm Post subject:
WTB 555 VCO PCB |
Hello!
I'd like to order one of the 555 VCO PCB.
I'm using Thomas Henry's VCO-1 currently, with good results.
My synth is a homemade 5MU style.
Thanks very much. |
MrZ
Posted: Mon Mar 18, 2013 10:54 pm Post subject:
VCO-555 bleeding |
This vco sounds great but I get bleeding to other modules thru the power rails.
Any idea for a solution ? |
Posted: Tue Mar 19, 2013 1:08 am Post subject:
bleeding is an issue that comes up in the forums from time to time for all kind of VCOs.
1st check your PSU. do you see a voltage drop? in other words, can it deliver enough current? _________________
fonitronik at
