  Antimon Antimon Waves
losing lower frequencies drastically when resonance gets to
Page 1 of 1 [8 Posts]
bsmith
PostPosted: Thu Nov 29, 2012 10:26 am    Post subject: losing lower frequencies drastically when resonance gets to Reply with quote  Mark this post and the followings unread
I finished building one of these and have been poking at getting it sounding right in my 12v euro rig. Started with the bridechamber kit - and going through the diodes to match pairs was a bit painful, so after not being satisfied with a first go with those I re matched some from a pile I had. Mine sounds mostly good, but I have a thing where just as I get into self oscilation - even a little, the bottom parts of the signal just drop out, like it suddenly sounds like a high pass filter. I've done the suggested changes for using in 12v, as well as lowering that 680k to 120k, and also made resistor changes when I saw that I was getting more like -7.5v on the -9v out - got that happening as well.
I think maybe I can do an even better job at matching resistors - after my second pass the 'bottom falling out' thing wasn't quite as bad, but it's still going on. Besides getting as tight a match on those pairs, are there any suggestions to getting that straightened out?
Cardinen
PostPosted: Sat Dec 01, 2012 9:23 am    Post subject: Re: losing lower frequencies drastically when resonance gets to Reply with quote  Mark this post and the followings unread
bsmith wrote:
I finished building one of these....
one of these... what ? Surprised
bsmith
PostPosted: Sat Dec 01, 2012 9:26 am    Post subject: Re: losing lower frequencies drastically when resonance gets to Reply with quote  Mark this post and the followings unread
I am so sorry, meant to post in the diode ladder filter thread. Sad
Cardinen
PostPosted: Sun Dec 02, 2012 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok, i think is a normal behavior with ladders-type filter, mine do the same especially the Diode ladder.
I hope this help.
bsmith
PostPosted: Sun Dec 02, 2012 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I hope this help.
I hear ya, and after talking to a few other people I've heard the same.
Buuuuut - man had a sea devils filter in euro in the past, and I don't remember the bottom drop off to be this drastic, so maybe there is tweaking I can do to get it a little mo' better.
yusynth
PostPosted: Fri Dec 07, 2012 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Loss of low-end at high resonance is a normal behavior for the ladder filters either with the Moog or the EMS filter. Cure for this can be added but these filters will no longer sound like the original ones.
Yves
bsmith
PostPosted: Sun Dec 09, 2012 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks very much for your reply Yves. What changes would be made that would address the lower frequencies dropping when resonance comes in?
yusynth
PostPosted: Sun Dec 09, 2012 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
The trick consists in picking the feedback signal after the Emphasis pot and adding a fraction of it to the output signal. This rquires simulation an calculations though and once again the filter will no longer behave like the original filter...
Yves
