  Antimon Antimon Waves
32.768 MHz crystal in Roland D-50
Page 1 of 1 [2 Posts]
noisyd50
PostPosted: Sat Dec 22, 2012 6:08 am    Post subject:  32.768 MHz crystal in Roland D-50
Subject description: Need help with specifications of Roland D-50 crystal
Hello! I need specs on the Roland D-50 32.768 MHz crystal for the LA32 chip. Can someone provide this info, or offer a suitable sub? There are pads on the board for C load compensation caps but are not used. I'm assuming these are for using a different type of crystal? Thanks everyone!
Mongo1
PostPosted: Sat Dec 22, 2012 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
That frequency is very common - I think it was originally developed for cheap watches. You should be able to put just about any similar crystal in place.
Regarding the caps - those are generally provided to increase the likelihood that the crystal will oscillate - they must not have needed them.
Anyway, these things are real cheap - if this one is mechanically compatible, it will probably work:
http://www.mouser.com/ProductDetail/ABRACON/AB-32768MHZ-B2/?qs=sGAEpiMZZMtgSs4ktXb8pkJ6X6uY%252bpzU
If you're not sure, you could just pick two or three different ones, and order them all - one of them is bound to work...
Good luck!
Gary
